Old 02-28-2009, 10:18 PM   #1
lapeer20m's Avatar
Re: Whistling through the doors
find a way to make the door seal better. Could be as easy as replacing the stock weatherstripping around the door, or adding new weatherstripping. Could be more complicated too, but ultimately it sounds like the problem is air coming in from around the door. Stop the air, stop the whistle.
adding a small wind deflector around the door may also solve the problem, but might take a bit of trial and error to get right. i was thinking something similiar in size and shape to the rain gutter that's on the outside of a bus.
Old 03-03-2009, 07:41 PM   #2
Coachwork: gmc
Chassis: g3500
Engine: gm 350
I had the same problem....I was able to fix it by applying foam weatherstripping that is designed to cut the draft from windows or doors. It has a stick side wich worked out perfect. I now have no noise even at 70 mph!
GuaGua is offline   Reply With Quote
pocket doors thesaltydog24 Conversion General Discussions 18 11-09-2017 04:36 PM
Way to lock doors cosis Conversion General Discussions 6 09-13-2017 01:08 PM
What did you do with the emergency doors? Noonien Short-Bus Conversion Projects 7 08-13-2014 11:18 AM
inside doors gbstewart Conversion General Discussions 2 05-02-2011 10:53 AM
storage doors beltburner Conversion General Discussions 4 09-28-2008 12:03 PM
