Old 11-05-2016, 09:44 PM   #1
Scared to Post
Window screens that WORK
I have been living in my short bus full time for the last 7 months & have been very pleased with the way I installed the screens. Here in Texas with all the bugs, it is critical to have some sort of insect control.
Here's a quick video I put together to show what I did & why it works.
https://youtu.be/aWl--435anc
Fxrflyer is offline   Reply With Quote
Old 11-07-2016, 08:20 PM   #2
AlleyCat67's Avatar
Year: 2005
Engine: Detroit MBE906
I like that.... I may have to do something like that when I get to that point, I won't want to run A/C all the time.
Old 11-07-2016, 09:21 PM   #3
zelseman's Avatar
Engine: 6.5L Turbo
I like it too! I might steal some design elements from you when I get to mine.
I had been thinking about using magnets to attach the screen, but I like your idea too!
zelseman is offline   Reply With Quote
Old 11-07-2016, 11:07 PM   #4
Year: 1994
I like it the trim wood looks great
Geo Jeff is offline   Reply With Quote
Old 11-08-2016, 05:21 AM   #5
superdave's Avatar
Chassis: thomas
Engine: 8.3 cummins
Rated Cap: 11 window
nice job, looks good
my build pics
Old 11-10-2016, 05:01 PM   #6
Chassis: Collins
Engine: 7.3 powerstroke
Awesome. Really like it and thanks for sharing. I'm going to try something like it. I was originally thinking of sewing magnets and using those, but I think yours looks very professional and is a better option.
SweetSpot is offline   Reply With Quote
Old 11-10-2016, 07:37 PM   #7
REDD's Avatar
Coachwork: Thomsass
Chassis: FreightShaker
Engine: 5.9 Cummins 5 speed
Rated Cap: 2 ATV's and friends
Very clever, the foam gasket on the edges of the wood pinch the screen against the window frame. I'll have to look at mine to see how similar the windows are.
The foam gasket adhesive didn't sick, did you paint/clear the back side of the wood or just leave it?
Assuming... the screen is a kit you can cut to size, a got it from a local hardware store of sorts?
Old 11-10-2016, 08:09 PM   #8
Great idea, i love it.
I looked into screen kits at the local big box hardware store and they run about $9-13 depending on size and color. For our windows, about $10 each for a kit to do one window.
I have been pondering this for a while and have seen several ideas, your is by far the best I have seen. Your windows also look just like what is in my full size Bluebird.
Oldmopars is offline   Reply With Quote
Old 11-11-2016, 04:38 AM   #9
Marceps's Avatar
Chassis: Saf-T-Liner MVP ER
Engine: CAT 3126
Nice video! Thank you for sharing.
Is there any benefit to having screens on the inside? How about being able to slide them vertically?
Marceps is offline   Reply With Quote
Old 11-11-2016, 08:17 AM   #10
Chassis: B3800 Short bus
This is a great screening solution! It won't work for my double-pane skoolie windows, unfortunately. They panes stick out too far.
Old 11-11-2016, 09:41 AM   #11
Phatman's Avatar
Great work on your conversion. Not bad for a girl. Don't freak out, it's a joke. It took me a while to convince my daughter that she could do wood working as good as any man. She finally agreed. I noticed on looking at your other videos that you used EMT conduit for your shower curtain rod. Either find you an electrician or go buy you a 1/2" EMT bender and make it one continuous piece. You don't need the couplings to get in your way. I could have done it for you if I knew you were going to be at the Lone Star Rally. Oh well, GREAT JOB !!!!!!!
Old 06-10-2018, 11:05 PM   #12
Coachwork: GMC
Chassis: 3500
Engine: 2.6L Diesel
Rated Cap: 13A 20C
Magnets?
I'm poking around looking for screen window ideas and I keep reading about the use of magnets. Question - aren't the frames and tracks and most everything else to do with the windows aluminum? To what surface are you sticking the magnets?
GoatMom is offline   Reply With Quote
Old 06-15-2018, 03:01 PM   #13
Good job. I did the same thing with the wood in between the windows with the left over flooring but I went to Home Depot and found these adjustable size screens that you pull apart to fit your window. It happened to just the right size for the bus. But I do think they were $5-7 each but it was easy so I did it. But I been thinking of making my own.
Lolo1 is offline   Reply With Quote
Old 06-20-2018, 02:58 PM   #14
SpaceCoastDuck's Avatar
Coachwork: Ford
Great video. Thank you for taking the time out of your life to show us how you accomplished this. We have 2 large windows and 7 small ones that we have been trying to figure out how to screen. Thanks again.
SpaceCoastDuck is offline   Reply With Quote
window screens, windows
