Old 07-23-2015, 05:19 PM   #1
dannewtobusland's Avatar
Year: 93'
Coachwork: blue bird
Engine: Diesel
Can I use this to charge my 12v directly from my a/c generator?
Do you think i can use this to charge a 12v battery? (link below)
http://www.amazon.com/gp/product/B00...A2LH8DUZ1Q6T63
I already have a 7000 watt generator in my bus so i wanted to start small and try plugging into my already installed a/c plugs and charging a 12v battery.
thoughts?
So new I was born yesterday.
dannewtobusland is offline   Reply With Quote
Old 07-23-2015, 05:27 PM   #2
crazycal's Avatar
How much time do you have? I think it is more for maintenance then charging. I will delete your other post.
I'm hungry!
You Gotta Let Me Fly
Old 07-23-2015, 05:45 PM   #3
Year: 93'
Engine: Diesel
Its for burning man! I wanted to run the generator sparingly and use a 12v battery i have at night for a few lights and charge the battery while i ran the generator during the day.
is there something i can use to charge a 12v dc battery directly from an a/c outlet?
Old 07-23-2015, 05:48 PM   #4
crazycal's Avatar
Your gen should have a 12v connection.
I'm hungry!
Old 07-23-2015, 05:56 PM   #5
Year: 93'
Engine: Diesel
but i want to use my generator to charge a battery.. so i just connect the battery directly to the 12v output? and maybe add a charge controller?
thanks!
Old 07-23-2015, 06:39 PM   #6
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
If your generator has a12v output you don't need a charge controller. The12v output is for charging the generator battery. The output would be pretty small.
somewhereinusa is online now   Reply With Quote
Old 07-23-2015, 06:40 PM   #7
Year: 93'
Engine: Diesel
So how would you recommend charging a 12v battery with a 7000watt a/c generator?
thanks for your help
Old 07-23-2015, 06:45 PM   #8
crazycal's Avatar
You are using the gen during the day anyway, use that time to charge the battery. You need to check and see if the 12v is regulated so you don't overcharge your battery. Otherwise you might need a charge controller. I am not an expert but that's how I would do it.
I'm hungry!
Old 07-23-2015, 06:47 PM   #9
Year: 93'
Engine: Diesel
A simple charge controller would do the trick! Gotcha!
Old 07-23-2015, 06:55 PM   #10
Chassis: AARE
I would just use a regular battery charger, 20 amp or so. The newer ones are smart enough to not over charge.
battery, charge controller, electricity, inverter, solar
