Old 01-26-2016, 09:54 AM   #1
Engine: 7.3L T444E Navistar
Rated Cap: 48/72
Dash stopped working
Our check engine light came on and flickered off now about three times. Along with that the dash would not work. Gages stay at 0. But ABS light and air break pressure gage works. Any ideas if this is related to the check engine problem or if the dash is related to the flickering engine light.
BeverlyTheBus is offline   Reply With Quote
Old 01-26-2016, 10:06 AM   #2
Is there a common ground for all the gauges? If so (common)...it would be worth checking.
Old 01-26-2016, 10:13 AM   #3
turf's Avatar
my battery has 2 powerleads from the hot side. 1 goes straight to the starter, the other powers the dash and everything else.
my bus runs just fine when the electric (the second lead) is not connected.
like tango said: check your grounds
and check the hot side of your battery
Turfmobile Build Thread
Old 01-26-2016, 10:33 AM   #4
Rated Cap: 48/72
Runs without the dash
I'll have my husband look for that, runs although the dash is not engaged. So maybe the power leads, I-10 going through Louisanna shook us to the bone. Guessing it shook a few wires loose as well. Do you think these cords loose would effect the engine light or is this a separate issue? Bus seems to be running strong. We're about 12 hrs from home yet. Fingers crossed we make it without another break down.
#checkenginelight, #dashissues, #gagesdontwork
