Old 08-11-2015, 07:43 AM   #1
Send a message via AIM to KeiroD Send a message via Yahoo to KeiroD Send a message via Skype™ to KeiroD
Diesel to Hybrid or Electric Conversions
Hi,
So I'm obviously considering this as a possible option. Has anyone ever considered trying to get their bus to run on alternative fuels such as biofuel, electric or hybrid set-ups?
I'm pretty sure it's possible to do but very expensive to convert a bus to a hybrid setup on your own. Biofuel might be the easier route to go but it would require a lot of work to make sure you had enough to get you through to wherever you're going.
What about electric? Obviously, there's some way to satisfy the electrical needs... such as solar, plugging into a charger at some point and wind turbines. What else am I missing?
KeiroD is offline   Reply With Quote
Old 08-11-2015, 10:52 AM   #2
roach711's Avatar
Rated Cap: 19
Running a bus on WVO has been done at a reasonable cost and any diesel can run on biodiesel unmodified. WVO setups are a dual fuel proposition and keep the original diesel fuel tank for starting/stopping the engine on diesel to avoid the WVO gelling in the fuel lines. If you run out of WVO you switch back to diesel.
Going hybrid means adding a huge battery bank and one or more large electric motors to the drive train. After all that expense what have you gained? How long will it take to get a return on your investment?
Powering exclusively by electric is the least practical of all. You'd get a very limited driving range with few charging options. Roof top solar panels would take a very long time to recharge your battery bank so that leaves plugging in at a charging station if you can find one. Environmentally speaking, you'd effectively be running your bus on coal.
Two other options are propane and natural gas but both share the same problem - where do you fill up while on the road?
Old 08-11-2015, 11:41 AM   #3
What is WVO? I am unfamiliar with this term. I also did not realize biodiesel exists. Of course, it should've been obvious now that I think on it.
How would this be accomplished? I'll be checking out the alternative fuel subforum shortly.
True. At least, to an extent. I was thinking this might be impractical but... it's certainly possible. The range might suck. Or it might not.
But with LiPo4 batteries or similar batteries capable of handling that amount of load, I imagine it'd get expensive real quick, but still doable. Of course, the easier way to deal with all of this problem would be to buy an all-electric bus much like the Proterra buses... but those are super expensive.
Same response as above. It'd probably be impractical but then again... who knows?
Propane... as in the same stuff that you can get tanks of the stuff and exchange when empty? I have no idea how many places there are around the US that does propane refills but I imagine colder places might have more of these about.
Natural gas... again, donno about this one but there may or may not be enough refuel points.
Most likely I'd go with biodiesel as an alternative fuel solution. I was mostly thinking about this as possible options for what you want in terms of how to fuel your vehicle.
For now though, I shall troll through the subforum for alternative fuels.
Edit: Whoops, didn't realize I was already in this subforum. It's too early, dammit. :P
Old 08-11-2015, 11:53 AM   #4
M1031A1's Avatar
Chassis: Saf-T-Liner ER
Engine: 3208 CAT/MT643 tranny
Rated Cap: 87
WVO is Waste Veggie Oil. This is usually found in the fryers from fast food chains. WORD OF WARNING - WVO is LOADED with water, animal fats and other corrosive things that will tear up your fuel lines and, much more importantly, the fuel injection distributor pump and the fuel injectors! Short term gain, long term loss. The repairs can go into the tens of thousands of dollars depending upon the engine/fuel system. At the least it'll be several thousand dollars to repair. So, saving the fuel cost short term will cost in repairs down the road. I've seen this on Steel Soldiers several times. Always the break down happened at the most inopportune time as well. Just a cautionary warning. If you want to use pure veggie oil, it's more expensive than just using diesel fuel. So, unless someone comes up with the Flux Capacitor and can time warp, I'd advise against these so-called alternatives until a way comes to clean up the WVO to a useable state.
As far as electricity, et. al. is concerned, unless you're looking to buy a train, it's not worth the effort. The scale of economy makes it prohibitive at this point in time.
Just sayin'......
M1031
M1031A1 is offline   Reply With Quote
Old 08-11-2015, 12:06 PM   #5
Ah, gotcha. That should've been obvious to me...
Ouch. That's... yeah. At least I was already expecting to need to have a huge emergency repair fund. This comment pretty much confirms my thoughts in this aspect.
You mean something like this?: Crisco Pure Vegetable Oil
If not, what're generally considered the best pure veggie oil to use?
Just sayin'......
M1031
Yeah, when I initially looked at prices for those, I was like... Nope... nope! NOPE! That, and My poor wallet...
Old 08-11-2015, 12:13 PM   #6
M1031A1's Avatar
Rated Cap: 87
Crisco, or any liquid veggie oil will work. Baron Von Diesel engineered his diesel engines to run on pure peanut oil (perfect for me since I'm HIGHLY allergic to it) since he was in an area of Germany that, at the time, produced a tremendous amount of peanut oil. I have also done a tremendous amount of research on the Fisher-Tropsch (check spelling) in converting coal to diesel fuel/jet fuel. Prohibitive on small scale, but Germany did it large scale in WWII.
Old 08-11-2015, 12:18 PM   #7
Hmm. We might be able to do this with just the pure veggie oil, then. It's not difficult for me to obtain a large supply of it, though.
Now to find out how to make biodiesel fuel out of the veggie oil! Or, well... something similar. Peanut oil might be an idea there, too. Is there any guides for this sort of thing?
Google Knows All, it seems. One such resource is Journey to Forever's guide.
Old 08-11-2015, 12:24 PM   #8
The majority of commercial BioDiesel available in the US is made from soybeans and can be run in conventional diesels with little or no mods to the fuel system. The big exception being that it can gel at relatively warm temperatures compared to ordinary diesel and often requires a pre-heater just to get it to flow. It's biggest Pro factor is that it does pretty much eliminate the sulfur from the exhaust.
Home brews have had very hit or miss success due to the inconsistencies of the amateur "brewers". Can it be done? Yes. But you'd better have a very thorough understanding of the processes involved.
Another "alternative fuel" for diesels is used ATF. Automatic transmission fluid. It only requires filtering (10 micron, as I recall) and has excellent properties according to some users.
Injecting controlled amounts of propane has also been done for years. "Fogging" the incoming air with propane can yield significant reductions in fuel costs and is simple enough that the engine can be run either with or without the propane which overcomes any availability issues.
Just a couple of thoughts to ponder.
Old 08-11-2015, 12:26 PM   #9
Moderator
crazycal's Avatar
Engine: DT408, AT545
Rated Cap: 23 500 gvw
Curious how you got on this subject but don't know what WVO or biodiesel is.
I'm hungry!
You Gotta Let Me Fly
Old 08-11-2015, 12:31 PM   #10
Your mention of commercial biodiesel had me running off to research this as well. While I was doing this, I also learned there's a lot of biodiesel fuel stations now. Nice.
Maybe I won't have to make my own biodiesel fuel... probably best to keep a 20-50 gallon emergency supply in the event I need to refill to get to the next biodiesel station.
Journey to Forever's website seems to have pretty good documentation and instructions. Following this shouldn't be too much of an issue... should it?
Can you actually run the bus entirely off of that? I suspect no.
Yeah, I might just do that... especially for hills. I don't know but we'll see, I suppose. Will doing this with biodiesel present an issue?
Edit:
I was already familiar with biofuel for cars and trucks... didn't realize there was biodiesel as well for trucks and buses.
I was mostly concerned with how to run normal cars on biofuel... and while I knew that biodiesel consisted of veggie oil and other such natural things, I didn't know WVO was the term for waste veggie oil. Granted, the last time I did this research was a while ago and I may have also simply forgotten it.
My interest in biodiesel/fuel was sparked again by my decision to finally get myself a bus. Talking it over with a few friends of mine brought up the subject of biodiesel/fuel.
Now you know.
Old 08-11-2015, 12:39 PM   #11
Moderator
crazycal's Avatar
Just so you know, fuel is fuel. Doesn't matter if it goes into a car or truck or bus.
I'm hungry!
Old 08-11-2015, 12:40 PM   #12
Just you you know, fuel is fuel. Doesn't matter if it goes into a car or truck or bus.
True. Fuel is fuel but there are different qualities and types.
But still, you have a valid point.
Old 08-11-2015, 12:53 PM   #13
Engine: 190hp 5.9 Cummins
We have a electric lions bus at work. They just got it this year.
$325,000.
Not for me thanks.
Old 08-11-2015, 12:56 PM   #14
$325,000.
Not for me thanks.
Ouch! Yeah, that's definitely way out of my budget.
Old 08-11-2015, 01:15 PM   #15
The lions buses normally cost $125,000.
The electric option cost $200,000 alone.
We got 12 new lions buses this year on our fleet. Only one electric.
Old 08-11-2015, 01:20 PM   #16
Ouch. Hence only one electric. How is the electric, though?
I'm thinking biodiesel is the best way going forward from here. There's a lot of biodiesel stations... although the middle of the US seems to have a rather... distinct lack of stations.
Probably best to hold an emergency supply of biodiesel when going through there. makes note to add that to his conversion project when he has the bus.
Old 08-11-2015, 01:22 PM   #17
roach711's Avatar
Rated Cap: 19
What are your plans for this bus?
Most people using WVO are looking for cheap fuel and are willing to put up with the hassle of tracking down sources (which are becoming increasingly harder to find) then processing the stuff then making sure it doesn't gum up their fuel systems. Doing it on the road means you take your tanks and filters with you which takes up a lot of space.
Old 08-11-2015, 01:24 PM   #18
Buy a bus. Convert it. Convert to biodiesel.
There's plenty of stations in my area for me to run off of biodiesel until I can make my own.
I've tracked down some sources but I'm still chasing down some other sources but I think I'll be okay. It'll be a while before I start making my own biodiesel, though... but in the meantime, I don't mind buying my biodiesel from the stations around here in Ohio.
Old 08-11-2015, 01:32 PM   #19
roach711's Avatar
Rated Cap: 19
Sounds like you have a plan. Now the fun begins.
Old 08-11-2015, 01:37 PM   #20
Yup. I have a lot of notes about what I need to do, what needs considered and what options there are.
All in my GDocs. That's here: https://docs.google.com/a/heimkoma.c...it?usp=sharing
Of course, there's more that I haven't added to this one yet but... that's more or less the general outline.
