Old 12-09-2016, 11:37 AM   #21
dalez...That's one step more detailed than I've gotten. Up until yesterday, I was still considering micro inverters vs power optimizers. These are now out as I can wire the panels in parallel for the same benefit. My goal is to make the system as efficient and effictive as I reasonable can and avoiding as many single points of failure as possible. Your recommendation may help do that.
PappySki is offline   Reply With Quote
Old 12-09-2016, 11:43 AM   #22
Coachwork: Bluebird?
Chassis: 26ft Bluebird TC2000
Engine: Cumming 5.9 12v, AT545
Check out wholesalesolar.com, they sell panels by the palletload fairly cheap. Higher voltage house panels mostly. I'm wanting to run a 48v battery bank as well. The panels are mid to low 30v range, so you need a BOOST charge controller. Most are BUCK, as in they need panels with much higher voltage than the batteries. The MPT-7210 is a good example of a boost charge controller. But, it's only 10 amps, so you'd need one for each panel.
dalez is offline   Reply With Quote
micro inverter, power optimizer, solar
