Old 10-01-2014, 09:48 AM   #1
Chassis: Amtran
Rated Cap: 71
non Onan generators in the bus
Hi,
Can you tell me if anyone is using generators that are not made specifically for RV's in their buses, what I mean is installed in a compartment?
Thank you,
Tom
"This is my ship...the Nebuchadnezzar, it's a hovercraft."
~Morpheus
The Nebuchadnezzar is offline   Reply With Quote
Old 10-01-2014, 11:23 AM   #2
r_w
Re: non Onan generators in the bus
I PLAN to, I have seen many others here and elsewhere. I have a Honda already, might as well use it. 2000 watt, whisper quiet, and needs to change oil before it goes through a 5 gallon can of gas.
Honda/Yamaha inverters if you want QUIET like an RV genny. Standard "contractor" style if on a budget. Some are mounted on rear rack, some are in a belly storage box.
r_w is offline   Reply With Quote
Old 10-01-2014, 01:10 PM   #3
Chassis: Amtran
Rated Cap: 71
Thanks r_w
~Morpheus
Old 10-01-2014, 06:41 PM   #4
lornaschinske's Avatar
Rated Cap: 89
This with this tri fuel conversion kit added to it is what we will be running. I have the soundbox/permanent over-the-roof exhaust design laid on out paper and have sourced the materials. I recently bought a $30 5 gallon bucket of Deckover "OOPS" paint to use on the exterior of the box to water proof it (and other boxes). We won't be using this genny in a campground (unless the power goes out). We do not normally boondock but we do park in parking lots. With a good sized deep cycle marine battery bank (golf carts won't fit) and the 5 or 6 20# LP tanks we will tie together, we should do okay. After much research, this is the solution we came up with to suit our needs.
Fulltime since 2006
Old 03-23-2015, 01:24 PM   #5
juliol's Avatar
Engine: 3208 turbo Cat
Lorna, do you have a picture of this set up mounted on you Bus?
J
juliol is offline   Reply With Quote
Onan generators chev49 Electrical, Charging and Solar 4 05-04-2012 06:43 AM
Onan 4.0 BFA opus Classifieds | Buy, Sell, Swap 1 09-28-2010 03:56 PM
DC generators.... jkindt Conversion General Discussions 4 02-20-2010 11:27 AM
Generators Demonknight Conversion General Discussions 7 01-10-2008 05:00 AM
generators lapeer20m Conversion General Discussions 1 08-18-2004 05:32 PM
