Old 01-24-2016, 01:20 PM   #1
Sika's Avatar
Propane Engine?
I'm intrigued by the following Craigslist-ing, but I'm not sure that, besides the Westcoast, there are many stations for filling up on propane. Would that be inconvenient? Any ideas on what mileage could be like?
Maybe I'm just overestimating this deal as its already registered as an RV, and I'm intimidated by that hassle.
Thanks in advance for the feedback.
Sika is offline   Reply With Quote
Old 01-24-2016, 03:38 PM   #2
Jolly Roger's Avatar
Engine: Detroit 8.2
You can run as far as a tank will take or have extra tanks with you and for refill you have to find the suppliers in the area and pick one. There not like gas stations but if you spend the extra time planning your trip then you will be fine.
Propane goes boom because it is already compressed. gas is a little slower on the boom and diesel needs to be compressed to go boom? Plan your trips for propane refills and it is a workable option
Old 01-24-2016, 05:35 PM   #3
Sika's Avatar
Oh, I guess I had imagined something different than exchangeable tanks (like a BBQ grill) of propane. Thanks for clearing that up. I'll research what sorts of tanks are used and how far they go.
Hmmm, I'm still trying to gauge how good a deal is when I see one. Other than the strange fuel type, what are your thoughts on this bus?
Old 01-24-2016, 06:28 PM   #4
Engine: GMC
Rated Cap: 42
My experience is that propane is much easier on an engine than gasoline. I ran a Ford pickup on propane for about 20 years and it never used a drop of oil in 250,000 miles. I had a 100 gallon tank (not pound but gallon) and I filled up from the propane tank at my home. As was mentioned above there are propane suppliers in many towns that could fill you up while you are on the road, you just have to do your research and find the suppliers in the towns you will visit. Keeping a BBQ tank onboard would only be for emergencies.
JA Savage is offline   Reply With Quote
Old 01-24-2016, 09:20 PM   #5
Sika's Avatar
https://sandiego.craigslist.org/esd/cto/5367903805.html
Well thanks folks. I'm tempted....
Old 01-25-2016, 02:16 PM   #6
I doubt that bus has the 454 in it.
GM used the high block 366 and 427 in medium duty trucks and bus chassis but to my knowledge never put the 454 in anything except cars and light trucks. The P-series chassis used in small buses and moho's sometimes were ordered with the 454.
Be aware that any gas engine that has been converted to propane is going to be a real slow dog on hills.
The newer engines that have been designed and built to take advantage of the lower cost propane fuel are better in the power department.
But the lower power output, limited range, and problem of refueling is going to limit your ability to go very far from home.
Old 01-25-2016, 04:23 PM   #7
Chassis: International 1753
Engine: 6.9 International
Propane is a good fuel for daily routes, and inner city stuff. But I would stay away from it if you're wanting to travel any distance. It's not that you can't fill it up, It's that it's not as fuel efficient as a gas or diesel. So you'll either have to have a super large tank to go anywhere, or fill up pretty often.
Propane engines run extremely clean because propane is a gas at room temperature and pressure. That's why their engine oil's are always cleaner then gasoline and diesel counterparts.
I'd be leary of just any old conversion though. Propane seems to play hell on valves and their seats inside the engine. So make sure the engine was built for it and didn't just have the kit slapped on.
Old 01-27-2016, 09:17 PM   #8
Sika's Avatar
Thank you, Booyah45828 and Cowlitzcoach, for such concise explications. I appreciate it.
Old 01-28-2016, 11:17 AM   #9
I have never seen a town without a propane fill at at least one of the gas stations.
This is 2016 people. Propane is everywhere.
20 pound propane tanks can be plumbed to be used as fuel if you run out of propane in the big tank. No issue.
Propane is cheap. However I would never own any bus without a diesel engine.
Wowman
Wowman$$$ is offline   Reply With Quote
Old 03-21-2016, 11:13 AM   #10
booboo's Avatar
Engine: 454
Rated Cap: 2 and 2 arfs
propane
to the OP ...don't be afraid of propane. it is a great alternative fuel and we have been running our buses truck and of coarse some of the company's buses on it and it is cheap and works great. we travel every year down into the USA without any problem finding fuel stations that supply auto propane.
"I doubt that bus has the 454 in it. "
your information is not correct i own a 1999 GMC 72 passenger with a vortec 454 on propane from the factory just decommissioned.
we have put up a photo album in the photo section under "cowboy express" and this bus also is a 454 on propane.
if you have any question please feel free to PM me and i will try to help
thanks
booboo
booboo is offline   Reply With Quote
