Old 01-09-2006, 12:59 PM   #1
Elliot Naess's Avatar
Engine: 5,9 Cummins
Propane fueled engines
I just came across four 1979-1983 models that run on propane; for $500 each -- vs their diesel busses which are listed for several thousands. But I plan to travel cross country. How big a propane tank can I install before I have to register it as a WMD? Any thoughts?
Elliot
Old 01-09-2006, 01:15 PM   #2
Steve's Avatar
Remember the bus at the end of Mad Max, the gas tank filled the entire thing...
Old 01-09-2006, 02:55 PM   #3
Eric von Kleist's Avatar
Year: 1985
Coachwork: ThomasBuilt
Rated Cap: 60
IINM, one member had a propane bus but converted it to gas when he had his engine rebuilt. I recall someone talking about getting worse mileage with propane than with gasoline. I also recall someone saying that it's not always convienient to find a propane filling station.
Not that I'm against propane mind you...just things I've heard.
Eric von Kleist is offline   Reply With Quote
Old 01-09-2006, 03:08 PM   #4
Engine: 5,9 Cummins
Quite so.
Propane has a bit less energy than gasoline. But it is a much better motor fuel because it is already a gas when it enters the engine so it burns more efficiently. No droplets refusing to light in a timely fashion. Being a gas, it also causes less "wash-down" of the oil film on the cylinder walls, which reduces wear. And it brings less contaminants into the engine -- ditto.
So propane is a lovely fuel. It's the availability of the stuff around the county that worries me.
Grabbing the bus for the bargain price and converting back to gasoline does seem realistic. From what I know, it's only a matter of external parts, right? One of these busses has a 427 Chevy -- how hard can it be to find a caburator?
Somebody please talk me out of this!
Elliot
Old 01-10-2006, 06:16 PM   #5
captainkf's Avatar
Year: 1985
Engine: 366 propane
Rated Cap: 56
Well, It may have been my bus you recall hearing about. I have an 85 gmc bluebird that runs off propane. We partially converted it to live in while we moved (and lived in) our way across Canada. That's about 5000 km's.
The propane is a very effiecient fuel, however it does have it's down sides:
Availability is an issue. It can be difficult to find an automotive fueler. We had a few close calls in the maritimes. The major problem is you can't just top it up with a jerry can. You need a tow to the nearest dealer.
High burn temperature can prematurely burn out the valves, which is what happened to ours. We rebuilt the entire engine.
Large tank size. Propane requires a large tank to have any usefull amount of fuel and drive size. Ours is about 200 plus gallons and we get about 5 hours (fully loaded, moving, with a trailer) of 60 plus miles an hour drive time. So, a big tank. But on a bus it's not a big issue.
Positives:
Propane is much cheaper. Even if there is a power difference. Propane has less combustibles which gives less power and fuel efficiency. However we were paying less than 50 cents per litre and regular gasoline was over 80 cents per litre.
Very easy to switch to regular fuel. Just add a regular fuel tank, fuel pump, gas line, gauge and your set. You can also get a system that enables you to run dual fuels that you can switch back and forth with the flick of a switch.
We are in the process of switching our to gasoline to move back to Calgary for convience sake. Once there we will go the dual fuel system.
I hope this helps, if you have anymore questions please just ask.
-Richard
captainkf is offline   Reply With Quote
Old 01-10-2006, 07:36 PM   #6
Engine: 5,9 Cummins
Thank you -- that's wonderful information! For visual reference I can look out the window at the 250 gallon propane tank in my yard! Do you know if there is a legal limit on tank size? Well, never mind -- I would probably convert to gasoline or dual.
That 5 hour range is a problem indeed. On 200 gallons of diesel I drive an 18-wheeler for two full days.
Thanks again!
Elliot
Old 01-11-2006, 08:25 AM   #7
Year: 1985
Rated Cap: 60
Hey, CaptainKF!
Yep, it was your situation that I was referring to, although I didn't have the story exactly right. I didn't realize that the price difference between propane and gasoline was that great, either. I only buy about 20# of propane every 3 months or so for my little gas range...
Old 01-12-2006, 04:09 PM   #8
captainkf's Avatar
Year: 1985
Engine: 366 propane
Rated Cap: 56
Update: it's about 250 LITRES not gallons. big difference. Sorry about that. Switching between imperial and metric throws me off somtimes. The tank is located behind the stairwell and is flush with the bottom skirting on the bus. it is about 5 feet long. There is a bit over 2' in between the back of it and the rear dualies. My bus is a 52 passenger bluebird 33' bumper to bumper.
It's in storage right now or I would post pictures.
I hope this helps.
-Richard
Old 01-12-2006, 04:29 PM   #9
Engine: 5,9 Cummins
Ah, that makes more sense. Thank you for taking the trouble to correct it!
I fully understand. I grew up in Europe and now live in the U.S. Så jeg har to forskjellige språk, også. Oops... So I have to deal with two different languages also.
When we called, we discovered that the propane busses are actually located further from home than what the listing showed, so I'm turning down the pounding-heart dial a little -- for now.
Be well,
Elliot
Old 01-23-2006, 01:30 PM   #10
fmtaylor's Avatar
more propane info
I have an 80 gallon tank on my 429 B700 carpenter 40'. Due to tank filling restrictions (75%) you can only get about 60 gallons in one. I get about 5-7 MPG at 55 MPH fully loaded.
The power delivered is slightly less for propane than it is for gas, but you really cant tell the difference. The conversion factor is 1.3:1 which means 13 gallons of propane is equal to 10 gallons of gas. In some parts of the country this makes a big difference as the price of propane is very cheap (as low as $1.70/gallon) compared to gasoline ($2.95/gallon at the same station). In other areas of the country it makes less of a difference. I could drive about half a day before looking for fuel, which was perfect for me since I needed to stretch my legs anyhow.
Finding fuel however, can be problematic. Weekdays between 9am and 5pm is the only time you will be able to refuel in most cases. You can always fill up at a KOA or other RV campground, but it is much more expensive. Some places will refuse to fill you even though they have the ability due to licensing issues. (motor vehicle fuel vs camping fuel).
Still, with all of this I plan to keep the bus propane powered. First, it qualifies as a clean fuel vehicle. Second, the propane tank for an rv is already installed, all I need is a few vlaves and I can pipe it into the "house". Third, I have learned alot about getting fuel, I plan on adding the capacity to hold a couple of 5 or 10 gallon bar-b-que style tanks, which I can get filled anywhere, and plumb them into the system with valves for emergencies. And finally, propane powered engines live about twice as long as normal gasoline engines, which will make a big difference in the long run I suspect.
fmtaylor is offline   Reply With Quote
Old 01-28-2006, 03:21 AM   #11
Rick78EFI460's Avatar
I hear the lines about propane motors outlasting the gas motors a lot, but in my line of work, I find burned valves and other expensive problems occuring at a much higher rate. We converted our tow truck back to gas due to the much lower cost of keeping it on the road. YMMV
Rick Russell
Rick78EFI460 is offline   Reply With Quote
Old 05-20-2010, 11:09 AM   #12
Year: 1978
Coachwork: thomas
Chassis: ford
Engine: 406 Ford
Rated Cap: 25
Re: Propane fueled engines
too bad there's not a way to just press a key and delete these posts by the likes of smile 468. I can think of a real good use for one of his clubs...
bus-ted is offline   Reply With Quote
Old 05-23-2010, 01:05 PM   #13
Stuff's Avatar
Coachwork: Goshen
Engine: 7.3
Rated Cap: 25
heh spam eh?
back to the propane thing (which i know is 4 years old lol) biggest problem is filling.
best solution is to have a dual fuel setup. run the gas and propane. just run propane till you run out and switch back to gas
Old 05-23-2010, 02:27 PM   #14
Engine: 5,9 Cummins
Hey, youse guys! It's Sunday, so I'm gonn'a give one of my occational sermons:
Once upon a time, a lady backed her automobile out of the garage to take a trip, but noticed that the gasoline tank was nearly empty. She chewed on this problem for a minute, and came up with the key word "gas". So she jerry-rigged some sort of hose from the Natural Gas plumbing in her house, to the Gasoline tank in the automobile. This enabled her to take a trip all right -- just not the kind she had planned.
This is but one example of why I prefer to spell out "gasoline" and other words that might be misunderstood. "Gas" is one of the worst -- there must be ten different kinds of "gas" in American English. (Tooooooot. Pardon me.)
All right, sermon over. Cookies and ice cream in the annex!
Elliot
New to diesel engines telluriders Conversion General Discussions 2 12-10-2011 11:28 AM
GM Engines CAMO-MONSTER Everything Else | General Skoolie Discussions 18 08-17-2009 10:06 PM
Which engines should I look for? Which ones to pass on? Train-train Mechanical and Drivetrains 8 06-24-2007 11:40 PM
Changing Engines Jarlaxle Conversion General Discussions 4 06-12-2006 06:29 PM
All this talk about Diesel Engines... Steve Everything Else | General Skoolie Discussions 2 04-28-2004 05:26 PM
