10-26-2016, 07:56 PM
Year: 1974
Chassis: CHEVROLET C60 just under 19700 lbs body#B10353
Engine: 350 ci on propane
Rated Cap: 48
Propane powered & propane appliances
I have a few questions regarding propane.
My bus is powered by "liquid" propane but appliances are powered by "vapor" propane.
I'm wanting to have a propane cook top, refrigerator, heater.
How can both be done on a skoolie?
Can it be done with 1 tank?
Thanks for any information
Gordon
10-27-2016, 08:41 AM
Chassis: B3800 Short bus
If your tank doesn't already have a vapour and a liquid valve (double check, some tanks have both) there are still options.
The easiest might be to purchase and install a vaporizer regulator. I like the looks of the Impco AHR-50D, but I'm no pro on these things.
Here's a PDF of Impco vaporizer regulators: http://www.impcotechnologies.com/pdf...Regulators.pdf
There are also some dual valves out there. Here's one:
Dual Cylinder Valve for Simultaneous Liquid and Vapor Withdrawal 8556
These will be dependant on tank position I would think.
It's definitely worth stopping by an industrial propane place and having a chat. Some place that works on forklifts... Unplanned propane explosions are no fun.
10-27-2016, 09:04 AM
This has all got me thinking.. I now want a liquid draw propane tank!
I've been using typical 20lbers mounted under the bus. In the winter the vapour flow from the tanks noticeably decreases. A liquid-draw tank with an indoor regulator vaporizer would eliminate this problem. Interesting...
10-27-2016, 03:25 PM
Year: 2005
Engine: Detroit MBE906
That's an interesting thought for those of us who will need propane while living in colder areas... not sure how safe it would be though.
10-27-2016, 04:54 PM
Year: 1994
Actually what you want the colder it gets is a bigger tank. The vapor boiling off is dependent on temp and the amount of surface area.
So a system like a cell phone tower would use a propane gen set running a charging system. The cell tower runs off an inventor run by many battery's and and usually a solar array.
Here is were it gets tricky in the summer the small genset will run on vapor right off say a 20 or 40 lb tank. As the temp drops the evaporation slows. So what they do is install a 250 or 500 or 1000 gallon tank. Not dependent on the volume of fuel the gen set uses but based on the surface area of the propane in liquid form inside the tank. So if you lay a ten gallon tank on its side its 24" by say 10" of surface area. if you stand it up its about 10"around of surface area. In say 70f that's enough to evaporate enough vapor to run say a 5 to 8 hp engine. So if you have a giant tank several feet long and across you can run a good size engine in warm weather and in the very cold you can still run a good size gen set. this is all in vapor of course.
To run liguid you have to heat the propane to get it back to vapor like in this bus or a car it goes from the tank in liquid into a heat evaporator a small one with coolant heating it can create enough vapor to run about 350hp at wot.
using liquid you would have to put it back in a tank let it evaporate and expand then take it to your lamp or heater?
I have thought a guy could install two vapor tanks say 20lb each run a hose across each tank but only have one full of propane and a off the hose coming from the propane tank that is empty or maybe the middle of the hose would be fine. But now you have a large surface are for the tanks to evaporate and hold vapor. which your talking off the top. I do a lot of propane stuff and this should work for a colder area. in fact if it works better the more empty tanks you add the better it will work. a 100 lb tank with a 20lb tank would be a good combo I think.
A small flame on the bottom of a propane tank like fridge uses to heat the ammonia would do wonders as well. Give up a small amount of energy to get the gas out. anything above -41f is making it better. Sounds weird to have small flame on a tank but in a pinch it could save your life. a hand held propane torch on its lowest setting.
Of course verify this with your government before trying.
10-27-2016, 05:15 PM
Year: 2005
That sounds like an explosion just looking for a place to bust out.
If you must, keep the flame MOVING. Don't leave it in one place, you melt a hole in the tank and it's all over.
10-27-2016, 05:55 PM
No, what I was thinking of was having a liquid draw 20lb propane tank with a line that feeds an ambient temperature vaporizer on the inside of the bus. The warmer indoor temperature should be plenty to feed a properly sized vaporizer. Since the ambient indoor temperatures are almost steady (or at least we try to make it that way) the vapour production will stay mostly constant.
There are many ambient temperature vaporizers. Here's the first one that popped up on a search:
Beam 11A17 Air Heated Vaporizer
You'll note that it appears to be made of aluminum and has 8 fins for decent thermal transmission.
10-27-2016, 08:20 PM
 No heatey propaney tankey with flamey! Dangery go boomy!
11-21-2016, 09:18 PM
I am no expert yet, but there is no difference between liquid and vapor, it's just a phase change like water and ice, same fittings work with both, just depends which space the inlet is in , see the new thread I started about forklift tanks. If you can have a certified technician add the proper fitting and valve that will always draw from the Vapor space at the top of the tank, prevent liquid from getting to your Vapor appliances, (kaboom! 8-( ), then the only issue is getting the lines in place and proper regulation of the pressure for your appliances. Someone who does a lot of work on RVs or Vanagon / Westies should have no problem with this.
Definitely don't mess around with separate vaporizers or anything like that, and totally unnecessary end complicated and therefore dangerous, stick to tried-and-true standard solution gotta be willing to pay a professional
11-21-2016, 09:20 PM
Originally Posted by jazty
My understanding is these only work in the single hole vertical standing DOT rated tanks like the standard 100 pounders.
