Old 11-28-2006, 02:18 PM   #1
Run your bus off wood
While searching around for cool websites to add to our list of links … I found one titled.
Construction of a Simplified Wood Gas Generator for Fueling Internal Combustion Engines in a Petroleum emergency
This is amazing stuff…check it out.
http://www.gengas.nu/byggbes/index.shtml
Are you questioning my Aaa-thoritttyy ?
soused moose is offline   Reply With Quote
Old 11-29-2006, 01:13 AM   #2
lapeer20m's Avatar
it's been done! Around WWII it was a reasonably common thing in europe
Old 11-30-2006, 01:00 PM   #3
Here’s another great site….
http://www.builditsolar.com/
Old 12-06-2006, 04:04 AM   #4
While researching my section on Home Brewing Beer and Wine for our links site … I ran into a few interesting ones on distilling liquor …
Here’s a really good site on making and using ethanol
http://running_on_alcohol.tripod.com/
Old 11-23-2008, 07:47 PM   #5
Year: 1967
Coachwork: Superior Coach
Chassis: Ford 500
Re: Run your bus off wood
Howdy All
We are currently building the unit needed to power internal combustion engines on wood.
You can watch our progress in researching and building the wood gasifier at
http://primus.drclue.net/Power/WoodGas/index.php
The most complete instructions on the site relate to the downdraft gasifier
outlined in FEMA documents , but the one we are actually building is a
cross-draft version.
I've re-done the FEMA drawing , correcting some of it's errors and
at the same time I've rendered companion drawings to have coverage
for updraft , downdraft and side draft versions.
As things move forward , I'll be giving details on how and why it works ,
so that one can more readily adapt the information to whatever materials
you have laying about.
There is really only one item for which the measurements are somewhat critical
( The burn tube ) and I have charts detailing the dimensions required for various
horsepower/displacement requirements.
If your reasonably handy (which most bus people tend to be ) then this
project should be a reasonable undertaking.
--Doc
requirements.
drclue is offline   Reply With Quote
To those of you with a wood stove in your bus ... wtd Heating, Cooling and Appliances 14 10-17-2019 09:25 PM
This is why wood should not be used in a RV crazycal Everything Else | General Skoolie Discussions 5 01-31-2014 01:36 PM
Wood Stoves? chev49 Everything Else | General Skoolie Discussions 1 06-04-2012 11:11 AM
Wood Stove for Bus? Seeria Heating, Cooling and Appliances 0 12-15-2010 02:56 PM
Wood stove vonslatt Conversion Tutorials and How-to's 17 08-25-2010 10:26 AM
