Old 05-19-2016, 04:14 PM   #11
Chassis: International S3800
so I have a question... isnt it a bad scene to be grounding your 110 volt panels to the same frame that alot of your 12 volt stuff is grounded to? shouldnt you be running grounds to each appliance / receptacle.. and then WIRING a ground to the Generator or to the Shore power connection? and leave the Bus frame for the 12 volt stuff?
Old 05-19-2016, 08:17 PM   #12
Chassis: Blue Bird
Engine: ISC 8.3
Nope. If there's going to be an ac system installed in the bus, just like any other metal building construction, the safety ground should be connected to the bus body. Without that connection devices like ground fault interrupters and over-current circuit breakers can fail to operate, ie fail to clear some types of faults by automatically disconnecting the power.
Incidentally some inverters (specifically the Xantrex PROwatt model I have) instruct that their cabinet, which is connected to the ground pin on the built-in 120v receptacles, should be connected to the dc negative/ground. When I bench tested that inverter I learned the reason for this: left unconnected its chassis floats at 60v relative to the dc input. When an unsuspecting person rests one hand on the chassis and touches either battery connection with the other hand, it results in a pretty good shock!
Old 05-19-2016, 09:10 PM   #13
Robin97396's Avatar
Chassis: TC 1000
Engine: 5.9
Send a message via Yahoo to Robin97396
That sounds better than a car alarm. The old guys used to do that with model T coils to keep people from sitting on their car hoods.
Old 05-19-2016, 09:37 PM   #14
We've got the RV type, and it works pretty well. It's got a built in 3-stage charger that's completely automatic. We really don't even think about it. The biggest drawback is that it would be nice to have a few more 120v. circuits. We've got it maxed out with double breakers. That takes care of everything that we've got, but if we ever decide to add a circuit we're pretty much out of luck. I guess either way has plusses and minuses.
dadelay is offline   Reply With Quote
Old 05-25-2016, 06:42 PM   #15
Chassis: MVP
Engine: CAT 3116
OK, now I'm officially confused! I was under the impression that the grounding was done via the incoming shore power and not to the bus frame. I just bought a Progressive Dynamics 4560 All in One center, and the installation guide that came with it (http://www.progressivedyn.com/pdfs/110030%20English.pdf ) shows the panel's ground bar being wired to the incoming ground connection. It does not show a ground connection to the bus body?
Another reason for my confusion is that grounding it to the bus would not seem to accomplish much as the bus itself is isolated from the ground by the rubber tires..
Piersg is offline   Reply With Quote
Old 05-25-2016, 06:48 PM   #16
jester's Avatar
Chassis: RE200
Engine: 7.3L Navistar T444E
you still need to be thinking about a ground for when you arent plugged into shore. ie only running off your batteries. it does show it in your manual, your hardware has the "optional chasis ground in it" your main breaker hold down screw goes right over it. i think
check out my build pics
http://www.skoolie.net/forums/member...albums833.html
or my random writings... at
www.roadrunnerlogik.blogspot.com
jester is offline   Reply With Quote
Old 05-25-2016, 07:00 PM   #17
Chassis: Blue Bird
Engine: ISC 8.3
Right. Well, kind of. The ground-to-neutral "bond" connection is done for you in the shore power system. I'm not in a position to speak for Progressive, but I could at least speculate they don't mention connecting the panel's ground bar to the vehicle body because they're working in a world where RVs are made of wood, not metal. Of course it wouldn't make any sense to wire a wood body to the ground bar.
That's part of the reason why it's important. Though even if it sat on steel wheels, or had metal stabilizer jacks down, it would still be a poor electrical connection to earth.
Have you seen Mike Sokol's No Shock Zone writings? They're pretty good. His part IV addresses "Hot Skin" and part VII addresses "GFCI Theory"; both are relevant to why the bus body should be well grounded.
Old 05-25-2016, 07:02 PM   #18
Chassis: MVP
Engine: CAT 3116
Originally Posted by jester View Post
you still need to be thinking about a ground for when you arent plugged into shore. ie only running off your batteries. it does show it in your manual, your hardware has the chasis ground in it. i think
The DC side is grounded to the chasis, I understand that, and I can see an inverter being grounded if needed, but I think the panel itself is not grounded.
Old 05-25-2016, 07:15 PM   #19
Chassis: MVP
Engine: CAT 3116
OK, just read through this thread (http://www.skoolie.net/forums/f10/ho...-ac-448-6.html ) again, and downloaded no shock zone. Confusion is cleared up.
Old 05-25-2016, 08:15 PM   #20
The no shock zone should be mandatory reading for all us bus nuts!!!!!!
If you are using a portable generator like Honda or Yamaha you will need to change their floating grounds so that they ground back to themselves. Many portable generators have a ground lug on the control panel that the mfg suggests you wire to a grounding rod---how likely is that going to be? You can find a listing of generators with floating grounds and how to make their grounds go back to the generator rather than a ground rod. With a floating generator ground, it is possible for the "skin" of the bus to become hot (electrified). Under those conditions, should you happen to step out of your bus onto wet ground while you are still, say, hanging onto the step rail, you get to be the ground----a shocking (and potentially deadly) experience. Jack
