Old 04-04-2012, 09:42 PM   #1
bapos's Avatar
Chassis: International Amtran RE
Engine: DT466E/MD3060
Solar battery charger
I am on hold with my bus conversion till I get a job, so I am thinking about putting on of these http://www.northerntool.com/shop/too...2045_200422045 to keep the battery up on it. I am not sure what is drawing power but not a major concern as I have a deep cycle battery on it to to start it for now.
Its only 17 dollars so not like its a major expense to take on, the reviews seem to be good just a easy way to keep the battery up with little or not effort.
I think my cig lighter is bad so I may have to replace it but wont be very hard.
Let me know your thoughts.
Bapos
Old 04-04-2012, 10:10 PM   #2
Send a message via ICQ to mightybus
Re: Solar battery charger
That looks pretty good at a fair price. 47 people out of 51 gave it high reviews. I will order one now myself, to see how it does. Thanks!
mightybus is offline   Reply With Quote
Old 04-05-2012, 02:35 PM   #3
bapos's Avatar
Yeah I think its a good idea... Kind of tired of jumping off the bus. With that many people saying its ok dont think it can be too bad
Old 04-05-2012, 02:46 PM   #4
Stuff's Avatar
those are a common topper upper. the connection it uses you can buy plugs like that at automotive stores and just wire it right in lol.
Old 09-26-2012, 11:26 AM   #5
Coachwork: 2003 Thomas E-350 shorty
Chassis: E350
Engine: 7.3 Powerstroke
Rated Cap: 24
I had one of those on a bus with a very slow electrical draw down. It didn't keep up. Depending on how far north you are, in the winter it will barely make a fraction of it's rated power. A dash light is probably around 5+ watts; that thing is rated at 1.8w, and that will be under ideal conditions.
If it isn't grown, it has to be mined
elkoskoolie is offline   Reply With Quote
Old 09-26-2012, 01:27 PM   #6
Moderator
crazycal's Avatar
Engine: DT408, AT545
Rated Cap: 23 500 gvw
I have 2 like that. They don't provide enough juice to fry an ant. I think you want a little more wattage.
I'm hungry!
You Gotta Let Me Fly
Old 11-25-2013, 10:45 PM   #7
Coachwork: International/Thomas
Chassis: 3700
Engine: 7.3
Rated Cap: 73
If you live in the south you would want about 5 watts of panel per battery to keep it charged, in the north you might want 8-10 watts.
Make sure you check the voltage being put out at noon on a sunny day, it should be at least 13.5v to get even a partial charge,
It has a blocking diode which is good to prevent the battery from loosing power to the panel, clean the panel monthly, just a wet cloth should work,
My conversion thread, viewtopic.php?f=9&t=466746
BUBB is offline   Reply With Quote
Old 11-27-2013, 07:15 AM   #8
Chassis: TE2000 FE
Engine: 5.9L Cummins
The main reason for these are to maintain a fully charged battery not recharge a battery that goes dead because of a drain. They will only produce enough power to over come the self discharge of the battery. Sorry but this wont do what you want to do.
chuck
cschlessman is offline   Reply With Quote
Old 12-03-2013, 01:27 PM   #9
Diesel Dan's Avatar
Engine: DT466/AT545
BUBB and cschlessman, y'all are about a year late with your advice!
Gallery:
Conversion Thread:
viewtopic.php?t=4959
Old 12-09-2013, 02:08 PM   #10
Chassis: TE2000 FE
Well better late then never
Chuck
Solar battery venting? tomas_maly Electrical, Charging and Solar 3 10-07-2012 08:59 PM
Excersise Bicycle Battery Charger.. Thundarfoot Electrical, Charging and Solar 10 09-13-2009 01:23 AM
golf cart charger for battery bank? TikiBus Electrical, Charging and Solar 3 10-29-2008 02:51 AM
Fast charger for ni-cad battery packs lapeer20m Everything Else | General Skoolie Discussions 0 07-03-2005 03:46 PM
Good Basic Solar/Battery Information Eric von Kleist Conversion Tutorials and How-to's 0 09-10-2004 04:21 PM
