Old 03-22-2015, 10:48 AM   #11
even if you covered your roof almost completely, you'd still need a massive battery bank to go along with it.
Speaking of covering things entirely..I've been debating covering my entire bus in these
You can find them pretty cheap on ebay. Nothing wrong with them UniSolar just went out of business (like so many other solar companies).
Unisolar Peel Stick 136W Flexible Solar Panels Home Solar RV Boat Uni Solar Uni | eBay
bearbus is offline   Reply With Quote
Old 03-22-2015, 11:04 AM   #12
Zephod_beeblebrox2's Avatar
Year: 1994
Coachwork: carpenter
Chassis: international
Engine: 466dt
Rated Cap: 59
I'm trying to make this an all electric bus. In my house which has a water heater and a fridge constantly on, I pay about $10 a month in pure electricity usage. 100-200 kWh a month. It was 200kwh this February and 43f outside. February I paid more than $10 but most months its only $10 and 100kwh.
How does that translate to solar? Well, I figure if I have a backup generator running on diesel that should do a lot. There is the option of a diy roof mounted turbine too.
Zephod_beeblebrox2 is offline   Reply With Quote
Old 03-22-2015, 11:38 AM   #13
superdave's Avatar
Chassis: thomas
Engine: 8.3 cummins
Rated Cap: 11 window
[QUOTE=Zephod_beeblebrox2;104103]I'm trying to make this an all electric bus. bad idea unless your pluged in. research solar power, lots to it
Old 03-22-2015, 12:00 PM   #14
Year: 1994
Engine: 466dt
Rated Cap: 59
There's nothing that can't be retrofitted. I intend to move into the bus before its completed in order to make best use of my income. The bedroom walls are almost done. Initially water will be from a bucket as will be the toilet. Cooking will initially be a camping stove..
Mind, as I'm parked on my gfs land, I can't imagine needing to rough it before the bus is completed.
I'm going to have to see how far solar will go. Batteries are no problem. They're about $100 each in Walmart for deep cycle 12v. They look big enough too.
Speaking of batteries. What size panel would you recommend for keeping the 2 bus batteries charged? I tend to leave my bus parked for a month or so at a time.
Old 03-22-2015, 01:10 PM   #15
Chassis: B3800 Short bus
200kWh is a lot for a bus-roof sized solar array. It can be done, but it'll take up a good chunk of the space on the roof.
200kWh = 200000Wh
200000Wh per month / 30 days = 6666.67 Wh per day
I'm just guessing here, but I would say that at a suitable North American latitude you may get a couple hours of peak solar charging plus a reduced amount in the morning and evening. For simplicity's sake, let's just say you'll have 5 hours of peak solar charging.
6666.67 Wh / 5 hours = 1333.33 watts
So a solar array of 1333.33 watts could potentially provide you with around 200kWh of electricity, but (as you know) you would also need an appropriate battery bank. Also, this isn't taking into account seriously cloudy/rainy/snowy days.
100kWh a month is reasonable, though. 666.67 watts is easy. 2 or 3 good sized panels can provide that, though I wouldn't expect to be using electric heaters and the like off of this small of a system. The battery chemistry probably wouldn't like it (serious voltage drop) which would also add more heat to the wires.
These are largely made up numbers, but it may give you an idea of how solar panels translate into the type of electricity we use on any given day in a typical house. We use LOADS of electricity in our daily lives without even realizing it.
I have a 600 watt solar array on my roof and a 455Ah battery bank. The system works wonderfully for all the things I do with it: water pump, laptops, phone chargers, lights, fans, tools (even bigger ones like table saws), small 12v refrigerator, stereo. I tried a tiny space heater through the inverter for the fun of it some time back, though, and it imparts a pretty harsh voltage drop. I wouldn't want to run that for long.
Do you have any particular aversion to propane? Nobody is trying to force it down your throat, but my suspicion is that a diesel generator creating electricity to run a resistive device that creates heat would be more expensive (and loud) than a gas that, when ignited, instantly and silently creates heat. There are also some neat little propane on-demand water heaters out there...
Old 03-22-2015, 01:49 PM   #16
Year: 1994
Engine: 466dt
Rated Cap: 59
I am trying to keep sources of fire out of my motorhome. Its kind of important when you also have gunpowder in the mix.
100kwh includes my fridge and water heater. I suspect the water heater burns up more power than an instant hot water setup.
The cables won't like providing so much power to an instant water heater which is why I'm thinking of having an array of super capacitors close to the shower. They can deliver a lot of power quickly. They don't hold much but enough of them should do me for 3 - 5 minute shower. I might do something similar for high surge things like microwaves, kettles etc.
I looked at 12v fridges and decided the way to go with a fridge is a $80 dorm fridge and an inverter. It uses less power and has a lower cost.
Old 03-22-2015, 02:09 PM   #17
??? Which one did you have in mind? If you can, try to find real-life power consumption of the device. Personally, I have yet to see an efficient "beer fridge". From my previous research, size for size the 12v compressor refrigerators (thermal electric ones are useless) were far more efficient when running off of a 12v battery bank (don't forget the 10%+ inverter efficiency loss).
I tried to get some real numbers quickly, but I should be working so I'm not going to spend any more time on it
Nonetheless, I came across this guy's website: Fridge test 240V - 12V. He did a test of two same sized refrigerators; one purpose built for 12v, the other running off of an inverter.
Old 03-22-2015, 06:43 PM   #18
Engine: 190hp 5.9 Cummins
Large cable is a lot cheaper than having an array of super capacitors near anything. Super capacitors are not even cost realistic.
If being able to pull large current draws is important to you, than a good lithium Ion battery bank is the only way. This would be money well spent.
If you want to go completely electric, you need to go do a ton of reading on the electric car forum. There you will learn how to build, charge, and discharge high capacity lithium Ion battery banks.
The yellow ones in this link are the battery cells you need. It takes roughly 4 to make 12 volts. They range in capacity from 40 amp hours to over 1000 amp hours.
LiFePO4 Battery Cell : EV Assemble, LiFePO4, Electric Bike Conversion Kit, EV Charger, BMS, EV Components, EV Parts, All for EV!
Winston LiFeYPO4 3.2V 40Ah Cell [WB-LFP40AHA] - $55.00 : EV Assemble, LiFePO4, Electric Bike Conversion Kit, EV Charger, BMS, EV Components, EV Parts, All for EV!
With solar you don't want flooded lead acid battery's anyway. They are heavy, give of dangerous gas when charging, leak acid, and NEVER GIVE BACK THE ELECTRICITY THAT WAS PUT IN WHILE CHARGING.
Lithium Ion on the other hand returns all of the energy used to charge the battery to the consumer. Loss is almost not there.
It's been 5 years since I researched this. Basics are still the same, but the products will be better.
Old 03-22-2015, 06:51 PM   #19
Year: 1994
Engine: 466dt
Rated Cap: 59
The problem with lithium batteries is they are self contained bombs. Lithium + water = hydrogen. Add air and electricity and you'll see why I really dislike lithium batteries.
Lead acid batteries are cheap. Super capacitors give out high discharges while lead acid only gives low discharges. A pairing of the two seems ideal.
As far as weight, its a bus.
Its all something I'm going to dive into when I've completed the construction and the water supply. I might put a solar panel on the roof to power lights and USB chargers initially while using a camping stove if need be and showering cold.
Old 03-22-2015, 07:01 PM   #20
IMO
The percentage of issues consumers have had with lithium Ion battery's is so low your way over thinking this.
I use Lithium Ion battery's everyday as do most people. I may use them a bit more than some.
-My electric shaving razor.
-My cell phone.
-My laptop computer I'm typing this on.
-My Dewalt and Milwaukee hand power tools I use at work. These get used hard.
-The battery in my heated jacket.
-My flashlights
And the list go's on and on. 99% of us use them everyday without even realizing it. There is virtually no risk to using lithium Ion battery's.
