Old 01-05-2017, 10:53 PM   #51
Alan N's Avatar
Year: 1975
Chassis: Gillig
I like your stove.
Can you explain to me, a complete computer illiterate, how to post pictures?
Sufficient unto the day is the evil thereof.
Alan N is offline   Reply With Quote
Old 01-05-2017, 11:13 PM   #52
rjnye79's Avatar
Engine: T444e
Originally Posted by Alan N View Post
If you are going to run the stove pipe out the window it should be pretty easy.
Just make a metal plate ( tin/ sheet metal) to fit the window opening and run your stove pipe through the middle of it.
No need to get crazy ( and expensive) with insulated pipe.
You might want to make a bracket to keep the outside pipe from tipping. Just something light that could hook in the rain gutter and go around the pipe.
Keep it simple.
Keep it safe.
Show us pictures when you're done.
So, no worries about the metal plate getting hot and whatnot? Did you use regular stove pipe or chimney pipe?
rjnye79 is offline   Reply With Quote
Old 01-06-2017, 10:29 AM   #53
Rated Cap: Your mom +1
You'll be fine running it out of a window. That's basically what I did, except I've skinned all my windows so it just goes up from the stove, 90s and then goes out the wall, another 90 and then up over the ridge line of the bus.
I've never had a problem with draft. I get good complete burns with seasoned wood and haven't ever had a puff-back situation. Make sure wherever you go through (window or ceiling) you use double or triple wall pipe. There are pics in my build thread.
When on the road I just pull the pipe going through the wall and external chimney, cap the hole and cap the stove and I'm off like a prom dress...
Old 01-06-2017, 02:19 PM   #54
Alan N's Avatar
Year: 1975
Chassis: Gillig
A tin sheet the size of the window opening is not likely to get hot enough to cause problems.
It will have enough surface area to stay cool.
If you wanted you could mount a short (6 inch) piece of triple wall chimney to whatever you use in your window opening, then you for sure wouldn't have any trouble.
Old 01-07-2017, 12:46 PM   #55
rjnye79's Avatar
Engine: T444e
Thanks y'all! I'm also curious, if I use double/triple wall pipe, could I put it through a piece of plywood instead of sheet metal? Is that stupid?
Old 01-07-2017, 02:41 PM   #56
Engine: Navistar 7.6L
I would use two pieces of sheet metal with 1" of mineral/rock wool in between in place of the one window pane.
No need for double and or triple wall sleeve.
DoubleO7 is offline   Reply With Quote
Old 01-07-2017, 08:12 PM   #57
Carytowncat's Avatar
Wood is unsafe.
I used tin and it doesnt heat much at all.
I like the idea of rockboard between two sheets of metal.
