Old 04-21-2017, 11:05 AM   #21
Coachwork: Thomas / international
Engine: Dt 360/ spicer 5 speed
Rated Cap: 42
I too dream about a woodgas skoolie. Needing something to occupy my mind upon a breakup with my girlfriend, I decided to bbuild a gasifier from junk laying around my land.took about a month to weld up.i had it mounted in and running a little Toyota pickup for a.short time before fire season kicked in.it was super rough and made from my own design(influenced by YouTube and the net) but it worked! It worked well enough to push that little yota to about 45mph.thats with no engine mods at all.i had a little gate valve attached to the air intake that would serve as my air mix controller.it had a piece of conduit attached to it so I could adjust it as I was driving.in the only test I ran on it, it got about 4gallons of wood chips per mile.stull have the gasifier.been thinking about hooking it up to something again.!)
You could run a bus on woodgas.big engine-short bus.it probly won't go fast,maybe not up hills.you would have to stop a lot to find fuel. I feel it could be done though.
Best storey...picking up hitch hikers!
Ooh, also ran it out of chips once on the side of the road.we just started throwing anything we could find in there.it was still hot enough.got me almost home!
SolomonEagle is offline   Reply With Quote
Old 04-21-2017, 12:05 PM   #22
Rated Cap: 42
Woodgas yota
Old 04-21-2017, 01:45 PM   #23
Robin97396's Avatar
That's pretty cool to set up a wood gasifier.
I'm not quite at the same level but I did make a gasifier cook stove. Who'd have thought you could heat a pot of water with a hand full of pine cones?
I still think beans should be a good fuel for a gasifier.
Robin
Nobody's Business
This is why wood should not be used in a RV crazycal Everything Else | General Skoolie Discussions 5 01-31-2014 02:36 PM
Wood Stoves? chev49 Everything Else | General Skoolie Discussions 1 06-04-2012 12:11 PM
To those of you with a wood stove in your bus ... wtd Heating, Cooling and Appliances 12 01-07-2012 12:17 PM
Wood Stove for Bus? Seeria Heating, Cooling and Appliances 0 12-15-2010 03:56 PM
Run your bus off wood soused moose Alternative Fuels | Electric, Propane, Wood Gasification, etc. 4 11-23-2008 08:47 PM
