Old 07-12-2019, 06:43 AM   #21
Ronnie's Avatar
Engine: 345 international V-8
Originally Posted by Ineedabus1 View Post
Hi Ronnie!
Obviously you are familiar with this kind of engine. Can you recommend somebody on the West coast that specializes in these oldie engines?
I do not know anyone, but sure there must be.
Old 07-12-2019, 06:58 AM   #22
even though the OP isbt going to get this bus.. this brings up a valid point for Anyone looking to buy a classic bus..
Get in contact with Bus collector groups.. (yes we exist.. some convert, most keep them as busses) most are more than willing to help answer questions.. and chances are someone in said group has a bus similar to the one you are looking for..
for a bus like this one, the BusBoys is a good group.. there are many kinds of busses in that group.. some converted some not..
also anyone who is going to traverse the country in a classlic like this needs to have or learn some mechanical skills.. sure if you get a flat a mobile truck will change it.. but what if a belt flies off and shreds.. guaranteed that no auto parts store can look up the belt for you.. its up to you ahead of time to take note of the numbers on them.. or take them off and measure them..
blow an air line? would you have any idea on how to fix it? clutch linkage fall apart?
classic busses are an awesome way to travel the country and a piece of history like a classic car.. but anyone who has one will tell you to keep a fat wallet inside your fat tool chest aboard the bus.
Old 07-12-2019, 07:08 AM   #23
Ronnie's Avatar
Well said Christopher.
Old 07-12-2019, 09:45 AM   #24
Rated Cap: 37,400 lbs GVWR
"This bus has also received an upgrade of air ride suspension . . ." If it's a home-made modification of its original leaf-spring suspension, you'd better check how well it was done! Caveat emptor.
Old 10-05-2019, 09:55 PM   #25
Truly beautiful & Awesome 😎
Split stop is offline   Reply With Quote
Old 10-08-2019, 11:59 PM   #26
You do have to realize that the 6-71 Detroit is only a 6.7 liter, with the power around what you can get form a stock 5.9 12v Cummins. They were build it a different time when maybe we weren't in as much of a hurry and 35 mph up a big grade was just fine. You would need the same mind set as if you were driving a split window vw bus. The journey not the destination.
Gizmolannigan is offline   Reply With Quote
