Old 01-31-2018, 07:50 AM   #21
Coachwork: IC
Chassis: CE300
Rated Cap: 32
Polish the shiny stuff, paint the painted stuff.
Make SURE the rear suspension is 100% awesome or it could cost you HUGE $$$. Once the torsion bars wear out you have to fabricate a totally new rear suspension.
Old 01-31-2018, 06:13 PM   #22
Chassis: GMC Savana
Engine: 6.5 liter turdo diesel
Rated Cap: New 14, 0 at the moment
the Upkeep on something that size takes a few bucks. Some folks will run it till they canít afford something then park it(just till we can get it fixed) six months to a year later they sell it for nothing because their overwhelmed.
RRRVBUS is offline   Reply With Quote
Old 01-31-2018, 08:01 PM   #23
New tortialastics: Sulastic. REAR TORSILASTIC SPRING FOR EAGLE BUSES
My first bus was a 1980 Eagle 10.
I LOVED that bus and wish that I had never let it go. However, my Bluebird will get 10+ mpg vs the 7.25 mpg that my Eagle got and I can still buy new parts from Bluebird.
Old 01-31-2018, 08:03 PM   #24
Coachwork: IC
Chassis: CE300
Rated Cap: 32
I'd always heard they were obsolete! Man, that would make them much more viable. I may start looking after the wedding. THANKS!
Old 01-31-2018, 11:15 PM   #25
Coachwork: integral
Rated Cap: 37,400 lbs GVWR
If you're serious about getting that bus, you should invest some time reading all you can about them on the Bus Conversions Magazine (BCM) and Bus Nuts Online (BNO) forums. There's plenty of folk there who have or know lots about Eagles. Because it has been known for some Eagles to occasionally rust a little bit (he says with tongue firmly in cheek), you should check for bulging of body panels that would indicate that steel structure underneath is rotten, and whack any suspect areas to hear if any rust rattles inside or even dribbles out. The Torsilastic suspension is a potential moneypit, but they do ride nice. Make sure the engine has the correct CF-2 rated 40-weight oil in it and nothing else - 15W/40 will kill Detroit 2-strokes eventually. Some body panels may still be available from IBP, so all is not lost if you need a new bay door or something. And check the infamous drop box, the Achilles Heel of Eagles.
Good luck, John
Old Yesterday, 01:01 AM   #26
Originally Posted by brokedown View Post
A big 2-cycle diesel? Some folks swear by those. Detroit Diesel has a pretty good reputation and the 71 series was introduced around the same time they invented trees.
https://en.wikipedia.org/wiki/Detroit_Diesel_Series_71
Lol,
May be an old motor but if he paints the top and polishes the bottom it would look like a new one.
Miles O Roads is offline   Reply With Quote
eagle
