Old 10-21-2009, 09:43 AM   #1
Steve's Avatar
1985 Blue Bird PT36
My third bus, I will be flying out to Ohio this weekend to drive it home.
Old 10-21-2009, 10:02 AM   #2
Send a message via ICQ to mightybus
Re: 1985 Blue Bird PT35
Right on Steve!
We're going to have a lot of questions about stuff like the ceiling material etc.
Have a safe trip!
mightybus is offline   Reply With Quote
Old 10-21-2009, 10:16 AM   #3
Andreb is offline   Reply With Quote
Old 10-30-2009, 11:22 PM   #4
Year: 1983
Chassis: Carpenter
Engine: 8.3
Wow that rig is put together, your a luckie man, although if your anything like me you'll tear into into after a week because something is not right or should be better. Grats...
seth
"grease buddy" and all around nice guy
madpsalmer is offline   Reply With Quote
Old 10-31-2009, 03:04 AM   #5
cheezypsnookle's Avatar
Coachwork: Bluebird tc2000
Chassis: 3401-3502 ???
Engine: cummins 5.9
we looked into a beat down bluebird rv at a local car dealer and it was wrecked inside and they wanted 25k for so i cant imagine what that beauty is worth
cheezypsnookle is offline   Reply With Quote
Old 11-05-2009, 04:10 PM   #6
Steve's Avatar
Most things were not working in the bus, I am working on getting things working / finding the switch to turn it on / or figuring out what the switch does.
I will start posting some pictures soon, I will probably have to work my way from back to front as I get things sorted.
Old 11-10-2009, 02:44 PM   #7
Steve's Avatar
I went to fill up the fresh water tank this weekend and it started flooding the bus under the bed, in the bathroom and in the kitchen. I have a real mess to deal with now.
Old 11-10-2009, 05:41 PM   #8
Griff's Avatar
Year: 1982
Chassis: IH S1723
Engine: IH V345 Gas V8
What a drag! Lemme guess...it had new carpet & padding on the floor, too, right?
Griff is offline   Reply With Quote
Old 11-11-2009, 10:51 AM   #9
Seeria's Avatar
That sucks! Hope it didn't damage much.
Old 11-11-2009, 04:17 PM   #10
Steve's Avatar
Luckily it was designed that you can get an inch of water gathered in any compartment with plumbing before it will leak over into the carpeted areas.
Old 11-11-2009, 06:58 PM   #11
Griff's Avatar
Year: 1982
Chassis: IH S1723
Well there, at least that's one positive...I take it then, that it did not overflow the retaining compartments? I hope that was the case.
Old 11-15-2009, 05:01 PM   #12
Hey Steve whats the ceiling height? Do you know if all of the Wanderlodge ceilings are the same height?
Abbott is offline   Reply With Quote
Old 11-15-2009, 05:40 PM   #13
ezbme's Avatar
Coachwork: Thomas Transit Liner
Engine: CAT 3208 Turbo
(envious!) beautiful bus Steve!
ezbme is offline   Reply With Quote
Old 11-16-2009, 12:27 AM   #14
bikeforthelight's Avatar
Year: 85
Engine: Gas
Steve....I am hoping you post some pics soon. Looks great.
Im Johnny. I Bike For The Light. I love missions. I think students rock. I make my mark.
http://www.bikeforthelight.com
bikeforthelight is offline   Reply With Quote
Old 11-16-2009, 02:09 PM   #15
Steve's Avatar
The bus is a mess right now, I have pipes and hoses and wiring everywhere. I am supposed to drive it to Missouri this weekend so I should have it cleaned up for some pictures soon.
So far I found two busted copper water pipes. I know there is at least one more leak I haven't located and I am worried there might be more I hadn't discovered yet. I haven't put in the new hoses to test the system further and find the other leaks also I am adding valves in case a leak ever happens again that I can cut that part of the system out. I have never seen anything this complicated, I have to keep turning to the manual to remember where some pipe that disappears into the wall or floor is going to.
Old 11-16-2009, 03:02 PM   #16
Steve's Avatar
Re: 1985 Blue Bird PT36
Here are some pictures of the bedroom.
Rear with mirrors and Blue Bird clock.
Behind the mirrors is massive storage bays.
Bays have access areas hidden inside them.
This one hides the water heater.
And this one the drapery controls.
View of the ceiling and one of three rooftop air conditioner/heaters.
The ledge above the mirrors and below the clock hides a long panel of controls and switches.
Old 11-17-2009, 12:19 AM   #17
Year: 85
Engine: Gas
Dude....sorry bout the pipes. I had a problem like that with the RV i used last year. But that is an awesome looking bus. Love the bluebird clock. And the mirrors in the bedroom could be fun too. haha. very nice. is that a padded vinyl roof?
Old 11-18-2009, 01:11 PM   #18
Steve's Avatar
Yes luckily it is still clean and looks great.
Old 01-13-2010, 03:22 PM   #19
Steve's Avatar
Originally Posted by bender477
Very nice Steve , the coach looks like it is a variant of a TC series ? I see its a pusher and the rear Window configuration looks identical to my '91 tc2000.
It could be a variant of the TD series? It sits taller than the buses I am used to, not that the body is taller but that the chassis and body sit higher off the ground. Same headroom inside. I haven't used the bus yet other than my drive back from Ohio with it but after what seemed two months I finally have my plumbing straightened out and I can put it back together and start making it livable.
I was recently installing a new backup camera and I re-noticed the windows in the rear of the bus. I think you can no longer get them if I could get into that space it might be a good place to mount another camera.
Here is the new backup camera I just installed on the left, the old one is on the right. With the new IR LEDs for nightvision I was getting glare issues off the glass that I put the camera behind. My solution was to cut a rubber grommet in half and silicone it to the camera surrounding the lens. Then I could push the grommet right against the glass the camera had to look through and there is no way for the LEDs to reflect back into the camera. The IR LEDS on this particular camera give enough light to see 80 feet in total darkness they have a sensor to vary their intensity to current light conditions. The camera came with an adapter so that you can connect its BNC type connector to the normal RCA input of any television.
Old 04-06-2010, 02:26 PM   #20
Steve's Avatar
I need to pull a trailer with my bus but I have now found that the trailer hitch has been hacked up, probably to tow a car with a tow bar.
You can see the cut the back end off the receiver and have also removed the gussets that held it.
1985 Blue Bird For Sale Fully Converted oneyearroadtrip Classifieds | Buy, Sell, Swap 3 08-06-2014 03:09 PM
1985 GMC blue bird better fuel economy???? 1985bluebird GM | Chevrolet Drivetrain 9 07-22-2013 08:41 PM
1985 Blue Bird Motorhome mike jacona Classifieds | Buy, Sell, Swap 11 08-22-2011 08:04 PM
1985 Blue Bird 'Micro Bird' Griff Short-Bus Conversion Projects 34 07-21-2009 02:35 AM
1985 GMC Blue Bird (Bob) SamW Skoolie Conversion Projects 10 11-23-2006 08:38 PM
