Old 05-12-2016, 04:30 PM   #231
Chassis: International S3800
thats one beautiful GenSet! that thing will power your coach nicely!!!
Old 05-12-2016, 05:44 PM   #232
Chassis: MVP
Engine: CAT 3116
These guys have some heavy duty aluminium slides that have a load rating of 980lbs:
Jonathan Engineered Solutions | Excellence in Motion
Piersg is offline   Reply With Quote
Old 05-12-2016, 06:32 PM   #233
Offgr1d's Avatar
Chassis: VanHool T945
Engine: Cummins M11
Rated Cap: 47,000
Awesome link - I'll take a look at that company and get some quotes - thanks!!!
Offgr1d is offline   Reply With Quote
Old 05-12-2016, 08:25 PM   #234
Chassis: MVP
Engine: CAT 3116
Hopefully they aren't as expensive as they look!
Old 05-13-2016, 11:22 AM   #235
Also check out Mor Ryde as they carry a full line of sliding trays and other products. Cargo Sliding Trays - MORryde Products
Camperman is offline   Reply With Quote
Old 05-19-2016, 11:36 PM   #236
Offgr1d's Avatar
Engine: Cummins M11
Rated Cap: 47,000
So I could not find a cheap enough slide to hold $500 without being over $400. I decided to build mine and it came in at a total of $150 and a full days worth of work.
Here is the parts list:
$30 48 skate bearings
$34 24ft unistrut (superstrut)
$15 half sheet 3/4 plywood
$30 steel angle (2 1/4 x 2 1/4 X 1/4 thick) 24' this is 6 cuts at 48"
$15 aluminum sheeting (not required)
$10 rustoleum spray paint
$10 nuts / bolts / washers
$8 steel rod 5/8" x8'
It's built and the generator is mounted. I also added shock mounted feet to the generator home built from a double stack of non skid furniture rubber feet with fender washers between them. Works perfect to raise generator about 3/4" from the mounting board..
The flashing was placed all around the air vent opening on the mounting board and in the bay floor for the down-vent...
Pics below....
Old 05-19-2016, 11:41 PM   #237
Offgr1d's Avatar
Engine: Cummins M11
Rated Cap: 47,000
Old 05-20-2016, 12:35 AM   #238
Robin97396's Avatar
So simple it's clever. Nice job.
Old 05-20-2016, 07:07 AM   #239
that looks great!!
those big coaches are so nice you have all that under-belly room since the bus skirting goes down so low.. on a skoolie that gennie would never fit!!
Old 05-21-2016, 12:31 AM   #240
Chassis: Genesis
Actually, the 12k genset from Powertech fits on a school bus. Just. I measured!
Timelord is offline   Reply With Quote
