Old 08-11-2012, 05:41 PM   #1
Chassis: international
2000 international
I have a 2000 international 3400 with a 7.3 liter i want to put a cummins in it, anyone know of anything that will prevent this from happening, i haul a race car trailer and need more power. thanks
vgearhead is offline   Reply With Quote
Old 08-11-2012, 06:54 PM   #2
crazycal's Avatar
Re: 2000 international
Yes, how much you want to spend.
I'm hungry!
You Gotta Let Me Fly
Old 08-11-2012, 07:51 PM   #3
As little as possible, we have the motor to put in to it. They both are automatics also. what do i need that expensive
Old 08-12-2012, 03:37 AM   #4
crazycal's Avatar
Do you have the correct motor mounts, linkages, plumbing, trans adapter? Will the trans have to be moved back to fit the engine? If yes, the driveshaft will need to be shortened. If you have the parts already, it shouldn't be too bad. If you need to buy parts, it adds up quick.
I'm hungry!
Old 08-13-2012, 10:27 AM   #5
Motor mounts and trans mounts can be easily fabbed, and even driveshafts built if ya phase them correct and check the balance. I have found that it often takes as much time to mount oil coolers and/or build a new core support for a larger radiator, than making mounts.
Also the exhaust pipes have to be mig welded, fuel lines run, etc.
Changing a diesel engine i think, is easier than putting in a modern drive train in an old car.
I am not an expert on that either, since it was like 1966 when i built my first car frame, etc for the drags.
ol Trunt is the expert...
Old 08-13-2012, 11:34 AM   #6
We are a full service repair shop and junk yard, so we have access to alot of parts, lol lol, we build our own race cars so if we have to fab something up it should be no problem. We just didnt know what the major road block would be, our 7.3 is getting tired, and the cummins is barely broke in. Thanks for any help and advice
Old 08-13-2012, 11:36 AM   #7
So that answers alot...yes it will work go for it.
Worst case maybe have to push motor back to keep it out of the radiator....
Make sure to post pics
Old 02-02-2013, 12:11 PM   #8
I rember reading about a kit u can get to swap out 7.3 out of a f250 and replace it with a 5.9 cum-a-part motor
google it you should find it.
Old 08-29-2013, 07:13 PM   #9
Coachwork: ElDorado
Chassis: Chevy P30
Engine: 7.4 liter 454 Chevy
Rated Cap: 24
Reason there is some dislike for the 5.9 is what is called the "dowel pin of Death"...
Before a mod was done a dowel pin in the timing gear area would come out and eat the gears and bust the timing cover.
Bullwhacker007 is offline   Reply With Quote
Old 09-06-2013, 01:21 AM   #10
crazycal's Avatar
More cubes is better.
I'm hungry!
2000 international w/7.3 diesel beaver Skoolie Conversion Projects 10 06-09-2013 06:55 PM
1993 International Blue Bird $2000 Castro Classifieds | Buy, Sell, Swap 3 09-03-2009 09:44 PM
TC-2000 AND ALL AMERICAN 1993bluebird Everything Else | General Skoolie Discussions 1 04-22-2008 09:54 AM
TC 2000 dlor1 Classifieds | Buy, Sell, Swap 0 07-03-2007 12:15 PM
Pablo TC 2000 captainkf Skoolie Conversion Projects 9 03-26-2007 08:23 AM
