02-15-2016, 06:55 PM
#131
Year: 2009
Chassis: Express 40'
Engine: Cummins ISX 650HP
Originally Posted by mrblah
Most parent wake up at 4h am to go to hockey games and practices or will go once every 2 years to an out of town tournament.
You built a second home on wheels to accomodate your son's racing.
That is a far bigger accomplishment than anything I could say about your awesome bus.
Good job sir!
Thank you.
This is exactly what you said..... it's used 100% for my sons racing, and was designed for this purpose, from the layout, the HUGE engine to effortlessly pull around a heavy trailer, and even the paint
We absolutely love it, and it's an amazing way for the family to spend the weekends in it.
02-16-2016, 07:15 AM
#132
Originally Posted by morefire
Hard to say about the price, because when I bought the shell, I also bought the brand new Cummins engine, PLUS I had them do the metal work and side skins...... everything else in the build I did myself at home.
I spend over $100,000. on this one. I could have done it for a fraction of the price, BUT I wanted the BRANDNEW coach instead of used, and I wanted all the high end features of those million dollar coaches..... Cummins-650 engine/MH4000 trans, PowerTech/Kubota 15K gen, the BIG Aquahot etc......
$100k is a bargain considering the upgraded engine and all the high end amenities you built into it. Well done!
02-16-2016, 02:26 PM
#133
Year: TBD
Hey Morefire, great thread. Thank you for sharing with the community. If you had an empty canvas again, what would you do differently? What worked for you exceptionally well?
02-18-2016, 01:48 PM
#134
Year: 2009
Great question, Honestly, I did A LOT of research and studied everyone's builds before doing my own, so I was able to rule out other peoples mistakes and make improvement's before even starting.
Sure there are little things that I would do differently like cable routing, but other than that there is only ONE BIG THING I should have done (I think). I think I should have installed a Slide while the coach was still a shell.
The guys who did the Welding for we would have bought it (used), and installed it for $5000, but I figured It was such a big coach, why bother....... I think If were to do it again, I would add the Slide..
Otherwise, I am 100% HAPPY with all my choices and components.
I'd go out and buy all the exact same components all over again, and go with the exact floor plan.
I believe them to all be the very best of the best, Period.
The power of this coach going down the road, or up hills is UNREAL. Thing doesn't even change gears on hills
02-18-2016, 07:03 PM
#135
Year: TBD
Most of the Coaches I'm looking at have Detroit Series 60s in them which disappoints me. What do you think (HP wise) the floor is for acceptability? 450-500hp? Or is 600+hp the only way to go in your opinion?
02-19-2016, 04:21 PM
#136
Year: 2009
The Series 60 is a good engine, but for me personally, 500HP is the absolute limit for minimum power. My coach came with a CAT 450HP/1450LBS torque, and I literally got in the coach, drove it home and hated it!! It felt like a big heavy sluggish vehicle where you had to Plan your passes around slower moving vehicles, and if there was a Hill ahead, they'd all pass you back and that frustrated the crap outa me.
I drove it back and had them Rip it out and install the ISX-650HP/2300LBS Torque and WHAT A DIFFERENCE.
The coach feels like it lost 20,000LBS, I can pass vehicles like I would driving my pick up truck, and the speedometer doesn't change at all on any Hill I've even encountered.
As a passenger bus it would probably be just fine, but once you build a motorhome out of it with all the weight of a generator, batteries, heating system, AC's, onboard water tank, and the weight of the interior cabinetry fridge etc.... It's a different story. Never mind adding a 10,000LBS Trailer.
You'd want either a CUMMINS ISX 15 Liter, or a CATERPILLAR C15 engine to give you this monster Torgue, but they don't usually put them in passenger buses, so you'll either have to have one installed, OR get the Series 60 Turned up a bit which would be the least expensive way.
02-19-2016, 05:56 PM
#137
Engine swap cost?
Morefire, what was the approx cost for the bigger engine and labor to install? Did you have to change trannys or do any mods? Thanks.
02-19-2016, 10:07 PM
#138
Year: 2009
Not sure exactly... probably over $30K for the swap.
But that's a Brand New Engine with all new parts etc...
I've seen Good Used engines for for $7500-$10,000, and you could probably have it all installed turn key for another $7000-$8000.
My Transmission was a B500, but I had I upgraded to the MH4000. (only a software conversion does this), otherwise, I didn't need to make any changes to run the bigger engine
02-20-2016, 04:33 AM
#139
Im surprised you didnt sell the house and just live in the coach. i know i would. very well done.
02-20-2016, 08:36 AM
#140
Year: 2009
Nope..... just a weekend warrior set up. Friday night after work, Load up with the family, bikes and supplies, and head to the Motocross track for the weekend, back home Sunday night, then repeat weekly for the summer.
