Old 10-28-2013, 08:54 AM   #11
Re: Coach Work combination
not on a bus...body work is body work (a bus just has a lot more of it)
cut roofs off cars to chop and off trucks to build cages etc
measure cut and reattach lots of big chunks to move around
if bodies are from same manufacture and same year and same factory build outside will be similar
JUST REMEBER THIS:
dog noses will have a body on a frame, take bolts loose and body can come off (you have a 40' frame)
a rear engine normally doesn't have a "frame rail" all the way back like a FE bus
so it will be 100% custom frame setup from wheels back..........the outside body work would be a breeze compared to that headache
Old 10-28-2013, 08:48 PM   #12
Yup, I have.
Old 03-03-2014, 06:40 AM   #13
That is a very interesting idea. I like the concept.
Is sectioning a body in your skill set? I think sectioning of same make bodies would easier than building storage, as long as you are comfortable with your skills to do so. Full frame buses make sectioning a body pretty easy work if you know how to do the attaching and final body filler work.
Have you made any further decisions on this?
Deezl Smoke is offline   Reply With Quote
Old 03-21-2014, 01:57 AM   #14
Coachwork: ElDorado
Chassis: Chevy P30
Engine: 7.4 liter 454 Chevy
Rated Cap: 24
If you have money Lots of it by the pound go for it. It would be cheaper to get a 72 passenger bus and swap in a larger engine..
I am also curious why you need 2000lbs. of torque to climb passes?
I used to drive a Freight liner with a big Cat in it and could pull a pass at any speed I wanted; BUT you could and some did burn the tread off of the tires from the torque with a full 80,000lb. load.
Bullwhacker007 is offline   Reply With Quote
Combination Package Alaska Stepvan Conversion General Discussions 9 03-29-2014 09:56 PM
coach-net gbstewart Everything Else | General Skoolie Discussions 4 03-18-2013 07:35 PM
DIY combination potty/shower? Jaybus Plumbing, Water and Waste 2 08-09-2012 10:39 PM
Coach Seats 64BPoquonock Conversion General Discussions 0 06-07-2011 08:19 PM
questions about your coach work? delbertinie Everything Else | General Skoolie Discussions 0 09-06-2007 06:35 PM
