Old 11-26-2018, 08:46 AM   #71
Brewerbob's Avatar
bob thats hoiw my DEV bus and superior are set up.. gnarly drives and all-position steers. I think they do sell specific steer tires, i just dont know of most using them.. im guessing in large fleets, esp in southern states where bad weather isnt an issue, all-positions are used because they can be swapped around as needed..
I might have to go bus tire shopping in the U.P. but I want the tread all the way around. Driving thru snow (and/or mud) with just chains on the rear makes about as much sense as steers on the front.
Gnarly drives make your bus sound cool in my opinion..
1) It's a bus. 2) It's an old bus. 3) It's a diesel 4) It's an 8.3L... It's going to make some noise without ever moving!!
Old 11-27-2018, 08:11 PM   #72
joeblack5's Avatar
Year: 98
Dory hatch skylight
Well mine are all steers, nice and quiet. Just do not drive in the mud or snow.
Today I made a skylight in the original escape hatch, same as I had done with Elfie. This time no holes and all sealant adhesive. Will see how it holds up but I love the light coming in .
It was to cold outside or in the shop for the adhesive to work with so in the living.
Originally I had dimensioned the hole in the hatch for a fantastic fan in but I like the light better. Now I think I can make new hole in the roof for the fantastic fan.
later J
Old 11-28-2018, 07:11 AM   #73
Brewerbob's Avatar
Better to err on the side of caution but I don't want a little snow keeping me from going somewhere.
That sounds like a whole (no pun intended) lot can go wrong.
Old 12-02-2018, 04:44 PM   #74
joeblack5's Avatar
Year: 98
Dory outside fold down table
Haha. I think pun was intended but no worries I will leave the Fantastic fan out for a while. Not to many flying bugs in the south west desert and not so arm in the winter that I need more ventilation then I have already.
It was a little warmer today and wanted to get something done. From our old 4x4 ambulance we had removed the running boards and I as going to haul them of to the scrap after 10 years of laying around.
Last minute I decided to give them a new chance on life. Quite a bit of band saw cutting to remove the lips so that two could be bolted together.
I need to make a couple of braces to give it more strength and would like to make an outdoor outlet so that we can connect an induction cook top outside
Maybe better to have a pull strap / chain on each end and a brace in the middle.
Later johan
Old 12-03-2018, 06:45 AM   #75
Brewerbob's Avatar
What's it's purpose in life? Looks like a food truck now; what's on the menu?
Old 12-03-2018, 07:48 AM   #76
Poffertjes, Stroopwafels, and Kibbeling!!??
Roll Your Own Build Thread
Old 12-03-2018, 08:01 PM   #77
joeblack5's Avatar
Year: 98
Yammie stuff .
I think for us being on the road does mean outside. Cooking inside adds heat ,humidity, kitchen grease to the bus. Better to do that outside like a summer kitchen.
Someone else had made a table on the side of their bus. Liked the idea and so this is our version.
Later J
Old 12-04-2018, 06:54 AM   #78
Brewerbob's Avatar
Later J
39 and cloudy tomorrow for the bus work. Don't think I want to cook in it.
Old 12-11-2018, 06:29 PM   #79
joeblack5's Avatar
Year: 98
Dory hatch skylight
While i as working to make racking for more solar, the spare tire, potential wind turbine my sweet came along with coffee. peeking thru our just installed skylight.
We were joking that people looking thru windows in hatches were always dying in the movies, sucked out in space, flooded with water....
Today the SS hardware came in to bolt the uni-strut thru the roof . Then I can start experimenting with a spare tire lift.
Unfortunately our small bus Elfie busted a corroded rear brake line so I have a difficult time getting bigger parts from the hardware store.
later j
Old 12-11-2018, 07:27 PM   #80
Ha!!!! Love the hatch pic!!!! And yeahyou are so right about what Hollywood has done with hatches over the years ... makes me think about all those sunken sub and cheesey disabled rocket movies !
Christopher
