Old 04-07-2015, 09:18 AM   #21
pretty slick, those are at least 3/8-16 grade 5 bolts right? I would hate for it to flip off
great idea
Old 04-07-2015, 11:44 AM   #22
dredman's Avatar
yep, big bolts, my only concern is dropping it off the side as I roll on/off the platform - 1st time was a bit of a struggle, and I am sure pushing it off backwards is even more
dredman is offline   Reply With Quote
Old 04-07-2015, 11:47 AM   #23
dredman's Avatar
oops, forgot about my security system installed in the rain yesterday......
45 seconds to install.............
drill hole, place padlock
Old 04-07-2015, 01:52 PM   #24
How about taking one of the "tube" wheel chock like this
and install carriage bolts like this upside down (or other ideas this is just a quick thought)
place into holes in front of ramp, push forward, drop in a pin so it can't move back, push front tire into it
raise up, remove pin and pull inside
to unload, put the tire holder on back wards at rear of ramp, install and push backwards, install a pin and then push bike on??
maybe this will give you ideas
Old 04-07-2015, 06:48 PM   #25
dredman's Avatar
maybe I am too dumb, but I am not sure how that would solve my issue?
the bike rides the lift fine, difficulty comes when moving the bike off the ramp?
Old 04-08-2015, 03:59 AM   #26
I thought issue was worried about it falling off the ramp in motion, reading comprehension was not a strong point I guess, sorry about that
So issue is not enough room for you and the bike pushing it on and off, causing you and bike to lean together?
I pictured riding bike onto ramp and stabilizing with legs, since its fairly level, getting off bike with wheel chocked load or unload, get back on and back off with legs
This would keep you from leaning over the side rails possibly dumping bike
It's clear in my mind...I am just mudding up the thought
What is wt limit on lift?
Old 04-08-2015, 07:11 AM   #27
dredman's Avatar
communication is not my strong point either Bansil
the issue is I have to PULL the bike onto the bus, which is VERY awkward. You can see me pulling in the video at 1:46, and you have to trust me that this NOT the way you want to move a bike. Not sure there is a solution, I might simply have to become a pro at pulling bikes from the front?
Weight limit is 800 pounds
Old 04-08-2015, 03:48 PM   #28
Winch inside the storage bay, pulley at the door, cable and clip down to the bike? Harbor Freight has small winches for pennies - they're crappy but would work fine for this and they're all 12V.
taskswap is offline   Reply With Quote
Old 04-08-2015, 08:37 PM   #29
dredman's Avatar
I am really curious about the guy with the Ducati that was a member...did he have a technique or did he wing-it like me?
Old 04-08-2015, 09:17 PM   #30
Engine: TE 444
Rated Cap: 12
lucky you, I have to make the door for my handicap lift taller so my bike will fit in
