Old 12-03-2007, 12:02 AM   #51
KC10Chief's Avatar
Rated Cap: 60
Re: Jacuzzi Bus IV
I was thinking the same thing about the tile. Using silicone instead of grout between the tiles. I'm not so much worried about flexing, as I am about jolts from potholes or bumpy roads. I was planning to use some more sub flooring to build my shower out of, and try to seal it up really well. But it's not a big space. I might spring for the marine grade plywood. It's not cheap though!
Matt
1993 International Carpenter 10 Window bus
7.3L diesel w/AT545
http://i74.photobucket.com/albums/i2...DSC02426-1.jpg
KC10Chief is offline   Reply With Quote
Old 12-03-2007, 12:22 AM   #52
lapeer20m's Avatar
Re: Jacuzzi Bus IV
i just re-watched all of the video's i made for the old bus' ebay ad. Can't wait till this bus nears completion and i'm able to go out and shoot a few more videos. they're a lot of fun.
I was actively working on this video when someone used the "buy it now" feature........then i was too excited to finish it!
Old 12-03-2007, 08:29 AM   #53
the_experience03's Avatar
Re: Jacuzzi Bus IV
A person could use a switch on that power wire, Elliot. I don't see a problem there. It actually wouldn't be a switch though...it would have to be solenoid or relay rated for 165 amps of continuous use. That's not really a big deal, but they are a little spendy ("spendy"...I'm from Minnesota). The other issue that scares me a LITTLE about those is that they are normally open which means a minor failure somewhere in the line would mean a major failure in the charging system. But...if both are completely separate and redundant that wouldn't really matter, atleast to get you home.
Old 12-03-2007, 08:44 AM   #54
Re: Jacuzzi Bus IV
it needn't be a solenoid. Just have a bigass heavy duty switch at the battery. This is assuming that the battery is in an accessible place.
pete c is offline   Reply With Quote
Old 12-03-2007, 10:55 PM   #55
reprobate's Avatar
Re: Jacuzzi Bus IV
I sure hope you all are around with your smarts when I start the electrical on my bus, it's the one part that is voodoo magic to me.
reprobate is offline   Reply With Quote
Old 12-03-2007, 11:35 PM   #56
Re: Jacuzzi Bus IV
Very true. But Elliot got me thinking about an airplane where you can kick off either magneto from the seat...and...well...I like big shiny switches on my dash to control stuff. Skoolie bling if you will...
Old 12-04-2007, 09:32 AM   #57
Re: Jacuzzi Bus IV
yeah, a schoolie isn't a skoolie if it doesn't have a controll panel that looks like the space shuttle. Lots of chrome toggle switches with led indicators and plenty of gauges.
Old 12-04-2007, 09:41 AM   #58
lapeer20m's Avatar
Re: Jacuzzi Bus IV
don't forget to add at least one fighter pilot safety switch!!
Old 12-04-2007, 03:23 PM   #59
KC10Chief's Avatar
Rated Cap: 60
Re: Jacuzzi Bus IV
I'm planning to totally rebuild my drivers area and make a new panel with lots of switches and lights. I'll work on that this spring.
That's a pretty good bus video. Where's the rest of it? I have been thinking lately about my 5 year bus plan. My wife totally thinks I've lost my mind. Anyways, I'm hoping to have my current bus done by May or June sometime. Well, I don't think that it will ever be done, but it will be ready to camp! Anyways, after that, I want to buy a short bus like a GMC Midbus. That conversion should be quite a bit easier and cheaper I'd think. I want it for a hunting rig capable of sleeping three people. So after that, I want to get the biggest TC2000 I can find. Sort of like Phil's bus. Something that's more economic, faster and bigger! 14 windows at least. I want to convert that bus into a camper as well, but with four bunks instead of two, a dinette, bigger bathroom etc. Once THAT bus is done, I want to take my current bus, gut it, and then turn it into a jacuzzi bus! Somehow, I plan to get all this done in the next 5 years. I could sure think of a lot of uses for a jacuzzi bus.
Matt
7.3L diesel w/AT545
Old 12-04-2007, 06:34 PM   #60
Re: Jacuzzi Bus IV
everybody knows there is just one use for a jacuzzi bus.
If younger and single, I'd sure as hell have one.
Jacuzzi Bus V lapeer20m Skoolie Conversion Projects 153 09-19-2012 10:21 AM
I put a Jacuzzi in my bus! bus-bro Skoolie Conversion Projects 6 12-14-2011 12:24 PM
Jacuzzi Bus VI lapeer20m Skoolie Conversion Projects 4 09-29-2011 07:16 PM
Jacuzzi Bus III lapeer20m Skoolie Conversion Projects 43 12-05-2008 08:31 PM
Jacuzzi Bus Steve Skoolie Conversion Projects 201 07-27-2005 01:07 PM
