Old 05-14-2018, 07:47 PM   #171
Coachwork: New Flyer
Chassis: D45HF "Viking"
Rated Cap: 51,600
Keep Ceiling Insulation?
Ok, need some help from some old-timers. I'm pulling down the "pegboard" ceiling, revealing the original foam insulation. It's packed pretty nice 'n neat....
Question - keep or ditch the foam insulation?
Context picture:
Various closeups:
MarkyDee is offline   Reply With Quote
Old 05-14-2018, 07:56 PM   #172
Chassis: MPV-EF
Context picture:
Various closeups:
Since it's not the cheap batt insulation normally found, and it's in good shape I would leave it alone.
o1marc is online now   Reply With Quote
Old 05-14-2018, 08:10 PM   #173
Rated Cap: 51,600
That's the way my wife and I are leaning, but there is a definite smell to it. Its not a bad smell, mind you, but it is a tad annoying.
What about sealing everything up with some 1-3 mil plastic before creating the thermal break with a wood ceiling (or such)?
Old 05-14-2018, 08:29 PM   #174
JDOnTheGo's Avatar
Coachwork: MCI
Chassis: 102 EL3
Engine: DD 60
Rated Cap: 50k
I am definitely old so I can answer this one!!
Keep it!
Mine was similar (but yellow). I could find no reason to remove it and lots of reasons to keep it. No regrets.
JD - Full timer out west
My Adventures & Build
Old 05-14-2018, 08:32 PM   #175
Chassis: Saf-T-Liner MVP ER
I'd be curious to find out what the material actually is, and its thickness.
I'd advise against adding yet another vapor barrier. Adding a second barrier will encourage any water vapor in the air that gets into the space, to condense out and have nowhere to go.
Steve Bracken
Build Thread
Old 05-14-2018, 08:52 PM   #176
Rated Cap: 51,600
Keep it!
Hahahaha! Its nice to be back working on the bus with you guys "riding shotgun"!
I'm not exactly sure what the material is, but I'll see if I can find out. However, I do know that the material is about an inch thick - along with the steel tubing that make up the skeleton. Its glued to the underside of the fiberglass roof. Poor roof needs a bit of repair as it cooked in the Houston sun for over a decade.
That's probably why the ceiling was some sort of "pegboard" with a felt underlay (well, overlay if you are going with gravity...). The "pegboard" and felt were riveted into place.
I'm thinking that the mildly annoying smell is coming from the foam. I was hoping to seal off the smell so it doesn't permeate my build. Maybe it just needs a good airing out? I do know that the roof has leaked in one or two places. Also, the roof topside does have some deep cracks.
Any ideas?
Old 05-15-2018, 12:04 PM   #177
Rated Cap: 51,600
Any ideas?
Ok, maybe I need to narrow down the question a bit:
Any ideas on how to fumigate the foam and make it smell better?
Old 05-15-2018, 04:12 PM   #178
Thomas1985's Avatar
Chassis: GMC G3500 Vandura
Engine: V-8 5.7L Gas
A few inches of insulation is more ideal. I would seal it in some way like you're talking about and then add a couple more inches of XPS. Having several inches in the roof will make a big difference in keeping your temperatures how you want them. Although that will only do any good if you're deleting some of these windows of course
- Thomas
The Daily Driver Bus Build
Thomas1985 is offline   Reply With Quote
Old 05-15-2018, 04:44 PM   #179
Chassis: MPV-EF
Spray it down with Fabreze.
Old 05-15-2018, 07:17 PM   #180
Rated Cap: 51,600
Yea, but I can't drop the ceiling too much more. I can't do a roof raise (huge roof-mounted HVAC), and my ceiling is only 6'6" from the floor.
And I am deleting windows. Of the 16 I will be deleting 6 of them for sure. However, I'm trying to get rid of more.
Yea, that's what my wife said after I posted the question. Its worth a try!
new flyer viking d45hf
