04-25-2018, 10:50 AM
#481
Coachwork: MCI
Chassis: 102 EL3
Engine: DD 60
I feel bad that I haven't been doing much work on Missy lately. That said; living in her has been pretty comfortable. Currently staying up high on the Continental Divide in New Mexico. Everything is working great and I'm enjoying the solitude!
04-26-2018, 11:24 AM
#482
thats a great testament that you are building your bus right and the way you want it!!
04-26-2018, 12:43 PM
#483
Coachwork: MCI
Chassis: 102 EL3
Engine: DD 60
That is a great way to look at it Christopher - Thank you!!
I clearly focus too much on the little things and the "lazy" aspect. Need to shift focus!
05-17-2018, 07:07 AM
#484
Coachwork: MCI
Chassis: 102 EL3
Engine: DD 60
My current location. Very high (7,500' MSL) which makes for nice cool nights (low 40's) and mild highs (mid-70's).
I finally decided I better get going on the ceiling again. First, I had to finish the foam board installation. I started with the blue 1" but I can't find that locally here in the SW. So, I switched to the pink.
I've had a terrible time deciding on the ceiling itself. Unable to find what I want, I decided to put some white board and see how it looks.
Turns out that I like it more than I thought I would. I'm not a fan of all the fasteners but am thinking that a more decorative screw head would help. Would also like to add some design elements - some sort of flowing/shaped panel with LED back lighting. That might work well with the shiny nature of the white board. That will be down the road... probably a long ways down the road at the rate I'm going.
For those that are trying to figure out tank sizes... I am pretty thrifty with water use. Not to say I am in conservation mode, I just don't use a lot of it. I make a big pot of coffee everyday, drink LOTS of water, use the toilet like a normal person that drinks lots of coffee/water, and take a navy shower every third day or so. I am also solo which helps a great deal (in more ways than just water use!! ). With that in mind, my 130 gallon fresh water and 105 gallon black/grey combined tank EASILY last a whole month. I could probably stretch it out to six weeks (but haven't).
05-17-2018, 08:43 AM
#485
Hard to beat those temps but it's just soooooo dry out there. Considering it's supposed to rain a week straight here (starting last weekend while I was out camping) dry might not be a bad thing tho.
OMG how can you stand the clashing?
Ewww. I don't mind the white but the glossy? Did you get it on purpose or was there no matte white product available? Maybe I'm too used to house ceilings. I don't think I'd want anything glossy even if it was wood paneling.
You could go all steam punk with some kind of fancy bolt head but that might require changes thru out the bus. Would be cool to see one done that way but I dunno about living in one. Probably get to be too much after awhile.
05-17-2018, 09:05 AM
#486
Howza'bout some old school auto trim screws?...
https://www.ebay.com/itm/50-qty-Chro...-/111056226529
Even better if found in SS.
05-17-2018, 11:26 AM
#487
Coachwork: MCI
Chassis: 102 EL3
Engine: DD 60
Originally Posted by Brewerbob
...but it's just soooooo dry out there.
Oh trust me Bob, if I could afford a tank of gas I would get out of this hell hole they call "the west" in an instant. I'd be back east where everyone belongs. For those thinking of going to the west - don't do it - PLEASE!!!
05-17-2018, 11:41 AM
#488
Coachwork: MCI
Chassis: 102 EL3
Engine: DD 60
That's about what is there now - temporarily. I'm currently focused on "testing" the panel more than the fasteners. No matter what I end up with for a panel, reducing the number of visible fasteners will be a priority. There are some options, such as trim strips or at least the same color fastener head. However; I'm leaning more toward some panels that hang down a wee bit (3D look), blend with everything else, and have some accent lighting. Being a bit creative, these can hide many of the fasteners.
The following is not the look I'm after but sort gives an idea of what I'm attempting to describe.
05-18-2018, 06:45 AM
#489
You can't be that broke. You're always driving around somewhere.
Not biblical by any means but it is getting a bit much.
05-18-2018, 09:59 PM
#490
Engine: CAT 3208
Rated Cap: 84 pass 36200 gvw
This comment strongly reminds me of when I was stationed at Whidbey Island NAS. I loved it there and all I told other Navy types about was how it rained all the time and never got warm.
Bob
05-19-2018, 05:19 AM
#491
Coachwork: MCI
Chassis: 102 EL3
Engine: DD 60
Bob
BOB!!! That is a terrible thing to do!!
05-21-2018, 06:56 AM
#492
Bob
Had to google that. I've really considered moving out there. Work at Navy base in Bremerton. May still someday oneday.
05-22-2018, 12:52 PM
#493
Coachwork: MCI
Chassis: 102 EL3
Engine: DD 60
Back in post #451 I mentioned the installation of a few LED lights in the ceiling. PNW_Steve recently asked for some data on these.
The numbers bounced around a wee bit during measurement - that always makes me nervous. Regardless, these are the 'observed averages'. Keep in mind, these are running from 24VDC system which at the time of measure was sitting at 28.3VDC (per the BMS).
For a single light/panel:
Brightest setting: 150mA at 27 VDC.
Dimmest setting: 100mA at 20.7 VDC.
05-22-2018, 07:08 PM
#494
Year: 98
Hi jd. Nice values.. Did you mean with the dimmest setting GS that your battery voltage was 20.8 volt per BMS or that the dimmer supplied reduced voltage at the led terminals?
This j
05-22-2018, 07:18 PM
#495
Thank you JD.
05-23-2018, 05:28 AM
#496
Coachwork: MCI
Chassis: 102 EL3
Engine: DD 60
This j
Howdy Johan! The latter. The battery voltage was constant. The dimmer was supplying reduced voltage to the LED's to accomplish the dimming.
06-03-2018, 07:02 AM
#497
Coachwork: MCI
Chassis: 102 EL3
Engine: DD 60
In a recent moment of weakness, I broke down and bought a satellite TV system. None of it is rocket science to setup/install so I won't bore you with the details - especially since a photo is worth a thousand words. If you really like details, they are here.
The antenna is about 13" tall and that is about 6" taller than the highest item currently up on the roof (Camco Cyclone holding tank vent). So, Missy is now about 12' 10" tall (calculated) at normal ride height.
06-14-2018, 07:09 PM
#498
Is 45' too long?
Hello, I'm in the beginning stages of converting a 40' school bus, and I had a chance to check out a 1998 MCI DL3 yesterday. The MCI has so much space and the big windows are really nice. I'm thinking about selling the skoolie and and converting the MCI, but I'm worried about the length and height. You seem to go to amazing places with your 45' coach. How is it driving on tight two lane mountain roads, dirt roads etc. And insight you can provide would be great.
06-15-2018, 06:29 AM
#499
Coachwork: MCI
Chassis: 102 EL3
Engine: DD 60
Howdy Capc!
I suppose the first thing to note is that there are many places I cannot go with Missy! Many, many, many places.
That said, I most certainly do get off the beaten path. The trick, in my opinion, is scouting the road/trail first. I tow a Jeep Wrangler so it is my scouting vehicle. I have a low and high ride feature and I use the high-ride when off-roading. It provides much more clearance under the vehicle. Of course, that puts the roof closer to tree branches. I put one of the four backup cameras on the roof so I could see these branches. It doesn't work very well but slightly better than nothing.
The larger you go, the more restricted you become. It is all a series of compromises.
I have an ongoing debate going with a friend. He and his wife have a 33' motorhome and they never boondock, are not full-timers, eat out all the time, and rarely carry more than a few items in their refrigerator when traveling. He thinks a big diesel pusher is crazy. However; I can't seem to convince him that it is about weight. I carry a huge amount of food, water, solar, battery, etc. plus everything I own (including tools, table saw, radial arm saw, bicycles, summer/winter clothes, keep-sakes, etc.). All of that adds up to weight and, obviously, requires space. I could live just as happily in a smaller coach but I would have to live differently. I could not boondock for a month at a time nor carry all of my belongings, for example. That's not necessarily a bad thing, just not what I wanted to achieve. It certainly comes at a price - both dollars and accessibility. Like I said, compromises...
06-15-2018, 07:33 AM
#500
Put it up front along the edging edge? Between the new disco ball and the edge in the center. <-- that distance.
Let me guess, he's got a little gasser engine in an F-450 chassis.
I went' looking purposely for the pusher in the skoolie. Just wish I had more transmission.
(including tools, table saw, radial arm saw, bicycles, summer/winter clothes, keep-sakes, etc.)...
You aren't using all of these tools while boondocking are you? I don't remember your solar setup but that would be some serious current draw.
Besides if I'm living vicariously thru you, you aren't supposed to be working.
