Old 05-19-2010, 10:01 AM   #1
Coachwork: El Dorado Aerotech
Chassis: Ford 30
Newbie: ElDorado/Aerotech shell has soft roof/leaks. HELP
Hi All!
I'm new to the forum and new to coach conversions. Here is the scoop. My friend bought a mini coach, Ford 3fifty (sorry five key is broken on laptop) with an El Dorado/Aerotech shell. I'm not sure of the exact year but it's a 90's model. We are in the process of modifying the bus to use for dog rescue/disaster response. I noticed a bow in the ceiling a little forward of the roof vent and from the roof vent to the back. It's a bit soft too which I believe is creating the bow around the pop up vent and allowing water to leak in. The shell appears to be all fiberglass, how in the heck do you fix this? Is there a seam along the top edges where you can remove the fiberglass roof panel? This bus also has a wheel chair lift on the back "passenger" side.
The closest I've come to a problem like this is replacing the transom in my classic fiberglass boat. The only wood was the transom between two fiberglass skins, had to dig out the rotted wood and use a pourable fiberglass transom product called Sea Cast. Have no idea how to tackle this horizontal roof problem. Any ideas would be greatly appreciated!
Linda
Doggone Shortie is offline   Reply With Quote
Old 05-19-2010, 11:14 AM   #2
crazycal's Avatar
Re: Newbie: ElDorado/Aerotech shell has soft roof/leaks. HELP
I think posting pics would go a long way towards solving your problem. Guy are visual creatures.
I'm hungry!
You Gotta Let Me Fly
I need all the advice I can get on my 1996 Aerotech Ford 350 Peachie Short-Bus Conversion Projects 6 10-09-2014 09:49 AM
PTooTi's 1996 Ford 7.3L gas E350 Eldorado - Aerotech ptooti Short-Bus Conversion Projects 42 08-31-2012 01:17 PM
Skoolie Newbie with a question about roof decking turtle Short-Bus Conversion Projects 0 01-18-2010 03:30 PM
BB shell on Craigslist Jarlaxle Classifieds | Buy, Sell, Swap 1 12-08-2008 06:48 AM
Skoolie Newbie... Roof Raise Questions jrock Conversion General Discussions 11 11-16-2008 09:49 AM
