Old 12-14-2015, 09:58 AM   #1
Engine: DT 466
Rated Cap: 44
Our Future Home
We are making a little progress. Hoping to have most of the welding and cutting of steel done before real cold weather gets here!
pwalker is offline   Reply With Quote
Old 12-14-2015, 10:24 AM   #2
Is that a new rear deck in the making?
Old 12-14-2015, 12:48 PM   #3
Engine: DT 466
Rated Cap: 44
Yes it will be a small rear deck and a place for my motorcycle while traveling. More work than I thought but will be worth it in the end.
Old 12-14-2015, 06:06 PM   #4
CaptSquid's Avatar
Chassis: HDX
Engine: Cat C7
Rated Cap: 84 passenger
Isn't that going to affect the departure angle?
Old 12-15-2015, 09:42 AM   #5
Don't know what size your bus is, but a 40 footer already has about 12' hanging out behind the wheels. As CaptSquid notes...that makes for a big change in the angle it can clear without dragging. Might want to add a roller on bottom like some of the big "Motor Coaches" have.
Old 12-15-2015, 12:18 PM   #6
Engine: DT 466
Rated Cap: 44
My skoolie isn't a 40 footer, from the rear axle it is 14 feet to the back bumper, so only 2 feet more shouldn't be to much of a problem.
I am getting a 10 foot ramp that I will be storing under the middle of the back end. I did some math and double checked on a website i found and it should not be a problem, getting a u-haul ramp from an old wreak
How To Determine Proper Motorcycle Loading Ramp Length| discountramps.com
It's coming together slowly but doing it right or at least I hope so!
Old 12-15-2015, 12:20 PM   #7
Engine: DT 466
Rated Cap: 44
Now that I think about it that roller idea might be some good insurance, just in case. I will have to look into that
Thanks Tango
Old 12-15-2015, 09:42 PM   #8
dredman's Avatar
is this the 1st post of this build?
My 3 Year Adventure
dredman is offline   Reply With Quote
Old 12-16-2015, 08:52 AM   #9
Engine: DT 466
Rated Cap: 44
No but it's been a slow start because of motorcycle riding and life
Old 12-16-2015, 09:00 AM   #10
2kool4skool's Avatar
http://www.skoolie.net/forums/f11/th...ins-12019.html
Don, Mary and Spooky the cat.
