Re: 351 motor locked up
if i had an engine totally locked up and it wasnt a model a or something like that = that needed the engine to be filled with penetrating oil or diesel and sat cause of stuck rings, i would probably pull the valve covers and intake to check valves and pushrods. or use the hf scope..
rings, water, crankshaft problems, cam stuff, etc can all make engine stuck.
