Old 06-10-2011, 04:54 PM   #1
Year: 1970
Coachwork: Chevy
Chassis: C/50
Engine: 366
Rated Cap: 3
366 power steering pump
replacing her power steering pump this weekend.
Thought i'd use some of you people for what yer best at,,,giving your opinion,,,
naw, just poke'n fun, but i could use any tips, tricks, things to look out for, things to inspect, evaluate, consider, regarding the instalation of the new pump.
any special thoughts on the gearbox or bleed'n anything?
Thanks kindly
Do not go where the path may lead, go instead where there is no path and leave a trail.
-Waldo
Follow Gumbys updated adventures at http://s29.photobucket.com/albums/c299/ ... rio/GUMBY/
TfallsTrio is offline   Reply With Quote
Old 06-10-2011, 06:59 PM   #2
bapos's Avatar
Chassis: 2001 International RE
Re: 366 power steering pump
By the looks of things its looks slick..... One way to try and get rid of that is to spray oven cleaner (i use the dollar general VERY cheap stuff) and hit it with a pressure washer. Not the best thing for the environment but it will clear it out nicely. I use it on older motors that have caked on oil and grease on them.
If you do it spray it on a hot day and let it sit say 30 min you will know when its ready when it turns a nice yellow brownish color. If you dont have a pressure washer go to the car wash. You can use a water hose but it does not have the ummph.
One thing also... start the bus and let it run while your doing this. Getting water in places and not starting till it drys out really sucks.
This procedure will help hopefully with wrenches slipping and skinned knuckles. Im curious as I have a 366 as well.
Take pics and post please.
Old 06-14-2011, 11:31 AM   #3
Year: 1970
Coachwork: Chevy
Chassis: C/50
Engine: 366
Rated Cap: 3
Go figger,
its not the pump itself thats leaking, its the "can".
More to the point, the,,,"can",,, is a seperate critter all together.
it is a discontinued item.
Ohhh, you can buy the innerds new, but you're down to boneyards for the can.
we've tossed around the JB weld or solderin' ideas, but the "can wall" is worn thin from the crank housing rubbin into it and the p/s fluid weakening the surrounding area.
we have also found that there is 3 different style "cans". today we are to disassemble the pump and can, to get the cans part number. Then we shall see if Spaulding actually has our fix.
ill post more about it, once the dust settles
hey bapos,
great suggestion about the oven cleaner. a couple squirts around the work area & and wipe with a rag made for a quick clean.
-Waldo
Old 06-14-2011, 03:21 PM   #4
frank-id's Avatar
Send the resivour/can to me
I will weld up the part and send it back to you. I will add some reinforcement. Frank
Old 06-15-2011, 10:13 AM   #5
Year: 1970
Coachwork: Chevy
Chassis: C/50
Engine: 366
Rated Cap: 3
well,,,,what'a thing to wake up to
A most KIND AND GENEROUS offer. I shall PM'ya this eve.
THIS,,,THIS right here is why i "hedged my bets" with skoolie.net
Thank you Frank
-Waldo
Old 06-15-2011, 11:15 AM   #6
frank-id's Avatar
steering pump
If ya send the part to me via the post office, the cost is small. My offer is to repair the tank for no cost to you. Send the tank with return postage included.
This should be a lesser cost than buying a new tank. I will demonstrate my welding talents. Grin. Frank
frank.id.crownatgmail.com
Old 06-15-2011, 04:15 PM   #7
Year: 1970
Coachwork: Chevy
Chassis: C/50
Engine: 366
Rated Cap: 3
now as far as seperating can and pump, the 2 stud bolts back out. backing them out just enough room to use them to "tap" the pump, so to push the pump out of the can. of course not damaging the O ring,,,
correct?
-Waldo
1991 366 Chevy power steering pump GreyEagle Mechanical and Drivetrains 0 07-20-2011 10:49 AM
power steering pump Atridox Short-Bus Conversion Projects 7 04-21-2011 12:18 PM
Need help with Power Steering kirkndopp Conversion General Discussions 2 07-07-2010 10:32 PM
Need Power Steering Pump for 1987 Ford 429 Trdoc1949 Classifieds | Buy, Sell, Swap 1 05-18-2010 12:37 PM
Power steering pump neeed KaptnKAOS Classifieds | Buy, Sell, Swap 0 09-03-2007 12:10 AM
