91 International 7.3 water pump
Does anyone know if you can change the hub that the fan bolts to only? It appears to be pressed on.
My 91 7.3 waterpump went out and i went to Autozone and bought one for $36 for a 91 ford f-350 7.3. The pump is identical and will fit my bus, with the exception of the hub. The one on heavy trucks has a different bolt pattern and higher stance to accomodate the stack of five or six pulleys, versus whatever was used in the ford (serpentine, maybe?)
Anyhow, after a visit to International, I cannot justify spending $400 for the same pump available for $36, minus the hub variation.
So, my question is does anyone know if the hub can be taken off the shaft by a machine shop?
Any advice is appreciated. Thanks!
