Old 03-08-2011, 10:38 AM   #1
frank-id's Avatar
over heat
I have a 1986 Thomas that uses a right angle gear drive for the fan. The gear box does require attention to lube levels. Fabricating a body scoop is a good addition. On my Thomas, the water pump failed and required replacement at $250 from Cat. The 3208 engines are a bit low on horse power and lots of foot energy is needed. Go to a hydraulic shop to learn about correction the no fan action with a turn. Frank
1990 Thomas Transitliner- "Thomas" Hormone Derange reddog Skoolie Conversion Projects 8 12-16-2010 09:22 AM
Keep the bus? Or too many problems? MonsieurBon Conversion General Discussions 18 07-10-2010 11:32 AM
Problems problems oh what fun they are dragonfly112 Conversion General Discussions 5 05-05-2010 11:09 PM
WVO problems? recycler Alternative Fuels | Electric, Propane, Wood & Biofuels 5 02-13-2009 12:06 PM
car problems TravelingMan Everything Else | General Skoolie Discussions 7 04-13-2005 12:51 PM
