Old 09-03-2018, 06:11 PM   #1
Coachwork: Aerotech
Chassis: E-450
AC issues
Wasnít sure if this should go in the HVAC section or not, since it has to do with the factory air I put it here. Just started on a long road trip today in a Ford E450 shuttle that Iíve been renovating. On the road 2 hours and my air in front dash went out. Fan blows for a second and then gets weaker and weaker. Vent feels cold, but no fan. If I let it set for a while it will do the same thing- blow for a minute or so but getting weak quickly. Any ideas??
Foxpen is offline   Reply With Quote
Old 09-03-2018, 09:40 PM   #2
Ronnie's Avatar
Engine: 345 international V-8
Two ideas,
1. could be evaperator freezing up and blocking air flow with ice. Usually low refridgerant can cause that. Can you turn off the a/c but leave the fan on for vent? If so do that and see if after 10-15 minutes air flow will start increasing. If it does then turn a/c back on till air does not come out again and repeat the cycle.
2. blower motor going bad.
