Old 05-17-2016, 03:22 PM   #1
tincaneasybakeoven's Avatar
Year: 95
Coachwork: Amtran ss-33
Chassis: Int 3800
Engine: dt444E
Rated Cap: 29,000
Cool add diesel power and reduce reliability here
http://www.freewebs.com/nevrenufhp/index.htm cummins cat international etc Cat 3126,3116, Cat 3208 & early model 3306, Cat 3406A,B,C , and later model 3306, Cummins Big Cam, Cummins 4BT,6BT, 6CT(3.9,5.9, 8.3), Detroit V92's, Ford/ IH 6.9 & 7.3 IDI, GM 6.2 & 6.5 Military Deuce & a half Lucas CAV pump Isuzu 4BD1T, 2T and VW 1.6 N/A International DT360,408,466,530, Ford 6.6 & 7.8, and Mack E7. IH DT466E, DT530E
claim common law i, a man; claim.... on facebook
if your not a man our doing it all wrong-kp
tincaneasybakeoven is offline   Reply With Quote
Old 05-17-2016, 03:48 PM   #2
Docsgsxr's Avatar
Engine: Cat 3126b 250 HP
Rated Cap: Only 1 seat
Interesting read, but I think I likes mine the way it came from the factory!
My build thread - viewtopic.php?f=9&t=467197
Old 05-17-2016, 04:13 PM   #3
Year: 95
Chassis: Int 3800
Engine: dt444E
Rated Cap: 29,000
aren't adjustable pumps are the way it came from the factory? adjustable pumps adjusted to the local conditions at the shipping site when shipped. might not be correct for your altitude or air density. the things electronic engines correct for/ most mechanical engines don't. As you wish, so shall ye receive.
Old 05-17-2016, 04:21 PM   #4
Docsgsxr's Avatar
Mine is an electronic controlled motor.........
Old 05-17-2016, 05:12 PM   #5
Year: 95
Chassis: Int 3800
Engine: dt444E
Rated Cap: 29,000
then its all ways adjusting itself. best you could do is a manufacturers reflash of your ecm.
diesel pump power
