12-10-2019, 08:09 PM
Chassis: MVP ER
Engine: CAT 3126
Adding Cruise Control?
I had heard a rumor that all HDXs have the connectors for cruise control even if the switches were not installed. So I took apart my dash today searching for any connectors. I did not find any save for one labeled for interior lighting. Not quite sure why given all the dome lights already work off of two switches. It was interesting to learn the dash is half metal, half plastic.
Anyway since this bus doesn't have connectors for the switches, how can I go about adding them? Since this is an electronic engine and transmission (MD3060), surely there must be some sort of interface I can connect into? While I'm at it, does anyone know where the TCM might be hiding? I'd like to send that off to get reprogrammed.
Oh almost forgot about this picture
This is the electrical compartment by the stairwell. It looks somewhat painful to take apart so I haven't done so yet, though ripping up flooring is getting monotonous and replacing a scraper every couple of hours is a drag as well so my attention is wandering to other stuff.
Unfortunately my camera sucks pretty bad and it's been raining the last couple days so I'm unable to take any decent pictures for right now either.
12-11-2019, 01:24 AM
Chassis: MVP ER
Engine: CAT 3126
That's kinda weird. My picture disappeared? But none of the other ones I've uploaded from Discord have. So I'll try it again.
12-11-2019, 06:19 AM
I am about as knowledgeable as you are.... I have heard the same thing and it makes sense to me.
I wonder if your local Thomas dealer could help? A shot in the dark but you may get lucky.
When I got ready to tackle my Vandallock system on my bus I called the local Bluebird dealer. The gent in the service department knew exactly what I needed. He gave me very specific directions to open a well hidden panel and remove the appropriate relay and where to connect the jumper in the empty relay socket. I could have spent hours trying to figure it out myself and probably never would have found the "hidden" panel that is under an unmarked cover plate behind the windshield wiper.
I have reached out to the same dealer half a dozen times for parts or technical support and they have been awesome.
The first time I stopped by the dealership I was greeted by I sign on the entry door depicting a 1911 with a green circle surrounding it. My kind of place Especially as I had my Gold Cup on my hip.
Good luck.
12-11-2019, 07:52 AM
Engine: 3126b 210hp
Rated Cap: 48
Cruise disable relay? Could or be that?cc
BTW, have you bypassed your interlock system yet?
A few of us have just run a wire from the st terminal on the key switch to the start button in the rear.
Dave
12-11-2019, 11:39 AM
Pic is still visible in post #1
12-12-2019, 12:48 AM
Chassis: MVP ER
Engine: CAT 3126
Yeah it's worth a shot, I need to go sometime soon anyway to go get a replacement strobe light switch that I've been waiting on for about a month now.
My dealer has been very friendly, but I am hammered somewhat by Thomas's poor part lookup system. Sometimes it's easier to go looking in the part book than online. It's VIN based too so if it's not something the bus had from the factory, it's much harder to get it. Speaking of which if someone has a VIN for a Thomas with CAT 3126 with AC I'd love to talk to them.
Originally Posted by Meathead
Cruise disable relay? Could or be that?cc Attachment 39914
Dave
Hmm, well it's probably safe to assume that it is involved somehow. I'll have to go back and look through all the diagrams on the covers and see what else might be related.
I have not done any wiring modifications yet, I plan to remove as much as possible. Though I'll tuck that info in the back of my mind as an emergency tool.
Weird, it's still not showing up for me. Oh well.
12-12-2019, 08:39 AM
Engine: 3126b 210hp
Rated Cap: 48
I have schematics for your bus. I will try to get them to you. I’ll have to study up on how to send them. Something about giving you permission to view my google drive. I don’t know.
12-12-2019, 08:47 AM
Engine: 3126b 210hp
Rated Cap: 48
Also I have your bus with AC.
I friend was helping me last year, got frustrated and called Thomas on a Friday afternoon. He got hold of an engineer who sent us schematics based on my serial number. It must have been a slow day/good mood/ perfect timing bcuz the guy has not been that forthcoming since.[emoji53]
Gotta run. I will work on getting info to you tonight or tomorrow.
Dave
12-12-2019, 11:12 AM
Chassis: MVP ER
Engine: CAT 3126
Dave
Oh wow that was so much easier than I thought, thank you! This would be so helpful and valuable! Could you also send me some pictures of your engine bay showing the belt routing and how the AC compressors are mounted?
12-12-2019, 11:39 PM
Engine: 3126b 210hp
Rated Cap: 48
12-12-2019, 11:59 PM
Engine: 3126b 210hp
Rated Cap: 48
12-13-2019, 12:37 AM
Chassis: MVP ER
Engine: CAT 3126
Thank you so much, this is extremely valuable information.
As for the engine bay picture, I'm surprised that your bus has fire suppression. The compressor location is interesting as well, but makes perfect sense. And it's driven off the large pulley where normally a fan would be mounted to in a conventional application. Doesn't look like it was the most pleasant thing to do engine repairs on. Now if I could just get a hold of that bracket....
12-13-2019, 07:02 AM
Engine: 3126b 210hp
Rated Cap: 48
This is what was said about my bus when I asked about the AC idler wheel that broke off.
Hello and Help!
https://r.tapatalk.com/shareLink/top...ink_source=app
12-13-2019, 07:06 AM
+1. im trying to add A/C to a friend's HDX for him and ive amassed pretty much all the A/C pieces we need except the compressor brackets for a 3126..
12-13-2019, 11:38 AM
Chassis: MVP ER
Engine: CAT 3126
Well if I find a couple for sale I'll let you know. I might try fabricating it, doesn't seem too complex. I would need higher quality, close in pictures particularly where it bolts up tho. Some measurements too.
Did you ever get that resolved?
12-13-2019, 07:11 PM
Engine: 3126b 210hp
Rated Cap: 48
Yes I did. I bought a wheel and spacer. I made my own adjuster bolt.
You know, that bracket is two piece and doesn’t look that hard to fabricate. Since both you and Cadillackid both need one I could take pics and make a detailed drawing.
Many ppl here have taken the time to help me, so I’m glad to do it.
Dave
12-14-2019, 12:12 AM
Chassis: MVP ER
Engine: CAT 3126
Bud, that would be so awesome if you could do that. Hopefully I can return the favor once I figure out this cruise control thing?
12-18-2019, 03:21 PM
Chassis: LXI43 slide
Engine: series 60
I had a truck with a 3126 that did not have cruise control,i did add the switchs but had to add wires to the engine computer,on the side of the engine.
I had a Cat tech do it,he had to pull the harness off the computer and remove a few plus in the harness and added pins and a few wires to the cab.
he had the pin tools etc.
12-18-2019, 05:28 PM
Rated Cap: 81
I added cruise to my 2001 Thomas MVP. The cruise is wired in through the high idle system so if you have high idle you might check again for the slots to plug the cruise switches near the high idle switch, or even if there might be some extra wires maybe it just needs the connector put on.
In mine all I had to do was plug in the switches and it worked! Switches were $15 each. A guy I spoke to said I might have to have the cruise turned on in the engine software through Cummins Insight Pro but I didn’t have to. Being a Cat, yours may need that through a similar software; and maybe being a Cat the cruise is wired differently than my Cummins.
12-18-2019, 05:34 PM
Rated Cap: 81
You might talk to a Cat dealer and ask them if there is a simple on/off program in the engine for cruise, if so there’s got to be a connector or wires to hook on to somewhere; then just run them up to the dash... hope it isn’t too difficult whatever it needs.
What infirmation does this “schematic” give you?
