Old 05-26-2010, 11:54 AM   #1
adjustments for more power?
I recently bought a '92 36 passenger Ford Wayne bus with a 7.8 Brazillian engine. The engine is new and the bus only has 88,000 miles on the chassis. It is topping out in 5th gear at about 45-50 mph. Can the gear ratio be adjusted to bump the top speed up a bit? If so, how difficult/expensive is this? Any thoughts on this would be greatly appreciated.
themissingparts is offline   Reply With Quote
Old 05-26-2010, 12:44 PM   #2
Re: adjustments for more power?
Someone told me that an overdrive unit would up the gear ratio in order to increase the top speed. Does anybody know anything about this? I am also concerned that flooring the bus for the entire duration of a long trip would put a lot of wear on the engine. Any thoughts would be helpful.
Old 05-26-2010, 01:42 PM   #3
lapeer20m's Avatar
both power and rpm's can be increased for free....assuming you have the bosch inline injection pump (i am pretty sure you do)
I did this to a few different buses, and was very pleased with the results.
check out the link:
viewtopic.php?f=6&t=588&p=3142&hilit=power+diesel+ engine#p3142
High altitude adjustments? opus Conversion General Discussions 0 08-31-2010 09:57 AM
DC or AC power? Locutus Electrical, Charging and Solar 3 07-31-2010 07:44 PM
re: more power themissingparts Mechanical and Drivetrains 7 06-07-2010 06:08 PM
No power wmah Everything Else | General Skoolie Discussions 2 06-11-2008 03:39 PM
ATX PC Power Supply to a 12 Volt Power Source vonslatt Everything Else | General Skoolie Discussions 3 02-15-2006 06:57 PM
