Old 10-07-2015, 05:56 PM   #1
Advice on a Allison 2000
I found a 30' 2004 international FE 300 model GA 39530. It has the DT 466 with an Allison 2000 5speed automatic. The gear ratio is 6.17. We want to convert it and tow a conversion van behind it and be able to go thru the mountains. I know the motor is what I want but have no clue on that transmission or gear ratio. From all of the reading I have been doing I was hoping for the MT643. Any advice is appreciated.
Ang1769 is offline   Reply With Quote
Old 10-07-2015, 07:43 PM   #2
Engine: 190hp 5.9 Cummins
That gear ratio will need to be replaced with something around 5.38 to a 4.10.
That bus will not go more than 45 miles a hour right at the redline of the engine.
Other than that, it sounds like a great bus.
Old 10-08-2015, 12:24 AM   #3
One more time...
Here is a gear/speed/rpm/tire size calculator that will crunch the numbers and tell you what to expect. You play "what if" easily with the bottom one on this page...
Engine RPM Calculator
6.17 gear ratio, allison 2000
