As you can see, my pedal assembly looks freakin gnarly. I want to remove it to sandblast and repaint it, but I can't figure out how to do this with the brake linkage. Does anyone know if the pedal assembly can be removed separate from the air mechanism under the bus? I'd rather not have to undo all the hose connections just to get this pedal assembly out.
The fuel pedal is easy, it is just fly by wire and bolted to the plate I am trying to take out.
Thanks in advance
