Old 03-29-2010, 06:37 PM   #1
Year: 1983
Engine: GMC 454 big block
Rated Cap: 54
Re: air compressor and regulator maintenance
I believe what yoiu are talking about is the air dryer and these should be serviced annually to biannually. I do not have a air system on my bus but my in my Semi usually eplace the desicant cartridge, the purge valve and the check valve. I drop the dryer right down and complety dsmantle and clean all dirt out. Also look around because many places that sell truck components have rebullt ones that arnt usually to much money and then you can just swap it out. If i new the type of air dryer u have i could give you better info.
1Buck is offline   Reply With Quote
Voltage regulator help!! Shortbus Nixon Short-Bus Conversion Projects 0 11-19-2010 05:55 PM
Pressure regulator, Kill-a-watt, outside shower, book SeanF Classifieds | Buy, Sell, Swap 2 12-20-2009 09:27 PM
Air Compressor Help!! GoneCamping Everything Else | General Skoolie Discussions 2 09-26-2008 10:11 AM
LP tank draws liquid is there a regulator avail to convert. JonCBrand Conversion General Discussions 7 02-09-2007 07:29 PM
air compressor mike Classifieds | Buy, Sell, Swap 0 02-23-2006 09:58 PM
