Old 03-27-2011, 01:19 AM   #1
Jive Turkey's Avatar
Re: Air Leak
Originally Posted by gocmndo
Anyone ever have the air brake switch leak? My bus use to hold the pressure in the tank for days. Now it is all bled out in two or three days. When running with the brakes engaged it is fine, when I push in the brake release I can hear air escaping.
Any thoughts?
Thanks,
-Martin
Air brake switch? Do you mean Stop light switch? Yes, they can leak. As far as the rest of you question it is unclear what you are asking exactly.
Here is something that will help you understand how the air brake system works and what components make it up. After you look at this it might help you to better understand and explain what you are experiencing.
http://www.community.gov.yk.ca/pdf/a...al_english.pdf
Jive Turkey is offline   Reply With Quote
Old 03-27-2011, 07:14 AM   #2
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
Re: Air Leak
If you hear air at the valve (switch?) it's bad. Quite common and not all that expensive.
Air pressure tank leak down bapos Mechanical and Drivetrains 9 05-30-2011 04:26 AM
Leak in Air Brake - How to test? kirkndopp Conversion General Discussions 8 05-15-2010 11:22 AM
Coolant Leak Problem GM 366 jaredg GM | Chevrolet Drivetrain 3 04-13-2010 08:57 AM
Injector Pump Leak dlor1 Conversion General Discussions 10 04-09-2008 10:13 AM
Air Leak ! (new problem) the_experience03 Conversion General Discussions 0 07-30-2007 02:16 AM
