12-21-2016, 10:10 AM
Chassis: Still dreaming about a bus
Allison 2000 Series
Before I pull the trigger on a Ebay bus, does anyone have anything to say about the Allison 2000 series 5 speed automatic? Good, bad, or otherwise? It is coupled to a Int'l 7.8.
The auction closes this afternoon. I don't want to miss out, but I don't need a POS either.
Thanks!!
12-21-2016, 10:32 AM
Chassis: IH 3800
Engine: Navistar DT466E
Rated Cap: 72 passenger
By all accounts they are superior to the 545 and 643. However, you have to run the Transynd fluid, and as these are still fairly "current" bits of hardware, replacements are not cheap.
I have not personally heard of anyone hating these things. Others will hopefully chime-in with personal (instead of third-hand) experiences.
"You can finally say you have enough horsepower when you leave two black streaks from corner to corner"
(Mark Donohue, famed TransAm driver)
12-21-2016, 10:40 AM
Thank you. I have since spoken to the local school bus guy, he pretty much agreed with you along with that service can be expensive due to the electronics.
I have put in my max bid and will leave it up to the stars from here.
12-21-2016, 11:05 AM
You can't win if you don't play. Good luck
12-21-2016, 11:39 AM
The 2000 seroes Allies are great trannies. And Transynd is a godsend in my book. Expensive yes, but can handle heat better than anything on the market.
12-21-2016, 04:53 PM
Sorry I didn't see this before now. The auction's probably over by now.
In case it hasn't ended, I'll go ahead and throw my 2 cents in. I have a medium duty rollback truck with an Allison 2400 behind a Cummins ISB. I've put 50,000 trouble free miles on the truck since I bought it. It has a little over 300,000 on the odometer now. Transmission shifts great and does fantastic at holding your speed back going down hills loaded. I've come through Fancy Gap on I-77 a couple times at about 25,500 lbs, and I never felt worried about over-using my brakes.
So did you win the auction??
12-21-2016, 04:56 PM
it's not quite over. I was just outbid. I not sure what I am going to do. I reached my max but I may go a bit higher.
Thanks for the info
12-21-2016, 05:04 PM
Thanks for the info
Good luck!
I remember that process well, and I'm glad I don't have to deal with that stress anymore.
12-21-2016, 06:22 PM
I didn't get the bus. It went for $3700. Doesn't seem too bad of a price for that unit. I just wasn't ready to go that high right now. Wanted to keep some of my Christmas bonus. Talked to the seller, would definitely bid on his stuff again.
12-21-2016, 06:34 PM
fancy gap is definitely a decent test.. though ive run it with my DT360 and my AT545 and didnt use much brake at all..
12-21-2016, 06:43 PM
Thanks to all for all the feed back. I really appreciate the help. This is the third bus I have looked at. Each time I have gained a ton of knowledge or shall I say I was skooled. This is my first time dealing with Ebay. Not real thrilled how the auction ended, but I guess that is to be expected. Live and learn. We'll get there eventually
12-21-2016, 08:44 PM
Not instant gratification, but certainly much less headache and hassle
I have enjoyed such good results with leaving things to the stars. I enjoy the saying ; "The universe has three answers; Yes, not yet, and "I have something better for you"
12-21-2016, 09:43 PM
But what was your weight? I had to keep it under 40 to feel like I had a chance of stopping if I needed to. The more weight you have, the harder (and more necessary) it is to keep your speed down.
Sorry it didn't work out. Auctions can be frustrating like that.
12-22-2016, 05:52 AM
im not sure what my actual weight is..its my 7 row carpenter.. its GVWR is 27500, I have yet to weight it.. it doesnt have much weight added over base stock.. actually probably very close to base empty stock weight as I took out some seats and then added in an A/C system and some batteries, a tiny cube frig, but no water tanks, new walls or anything.. its basically like a regular school bus.
maybe the AT545 has good holding power for lighter busses but not heavy ones.. both of my busses running 545s seem to pull right down when I drop into '3' on the hills.. totally opposite of what everyone says a 545 will do.
