07-13-2016, 12:52 PM
Allison ID help via shifter?
Hey Everyone,
I have been looking at a number of busses online that are being offered by folks that don't understand that Allison has made more than one transmission.
The list the transmission as "Allison". I ask "which Allison?". Reply "Automatic"....
Can you all give me any clues as to narrowing down which tranny it is by which shifter is visible in the pics?
I see a couple of distinct mechanical shifters and the electronic one(s).
Which transmissions used the electronic/pushbutton shifter?
I have only observed firsthand MD3060 and 2000 series with electronic shifters and wonder if the electronic shifter is a good indicator that the bus does NOT have a 545, 730 or 740.
Any thoughts?
Thanks
07-13-2016, 01:01 PM
The shifter won't tell you anything. They are speced by the chassis builders...not Allison. I have a 2200MH with a mechanical shifter (what I wanted) but could have had anything including electronic with a lever, buttons or even paddle.
07-13-2016, 01:09 PM
i may be wrong but i believe if you see an electronic one, its not the AT545.
in buses, i've only seen the AT545 with a simple lever selector with RND21
fwiw
07-13-2016, 02:26 PM
While the cable shifters are common on At545's, there are some with electronic shifters...like this one...
Allison AT545 Transmission Electric Shifter For Sale | VanderHaags.com
07-13-2016, 04:09 PM
fwiw
Mines shows RND321
Don, Mary and Spooky the cat.
11-27-2016, 03:28 PM
Can anyone help me figure this out. Allison md3060 1995 with Cat 3116: I have this. 0 IN SERVICE MODE 0 blinking displayed in my electronic shifter. My bus starts fine even with the shifter removed. The do not shift light stays on, and when I push the arrow up, and arrow down buttons the shifter will only display d1. I have never worked on anything before and Allison tried to sell my a new ECM over the phone. If you have any ideas for me to check it would be of great help.
11-27-2016, 06:09 PM
Coachwork: Thomas 72 passenger
Engine: 230HP DT466 engine MD3060 transmission
Not sure if this is going to help but this is my shifter; 1,2,3,4,D. I assume its a 5 spd. And the economy mode I assume means lock-up.
11-27-2016, 06:24 PM
Engine: 5,9 Cummins
Originally Posted by Tango
Wrong. That shifter shows RND4321, so it's for a 5-speed.
