Old 07-15-2011, 07:00 PM   #1
Stuff's Avatar
Re: Allison shifting between 1-2
consult a trusted transmission place for a checkup.
Old 07-15-2011, 07:39 PM   #2
GreyEagle's Avatar
Sounds like you might be ready for a service, at least a fluid and filter change..... around $200.00
GreyEagle
Roll - On...
GreyEagle is offline   Reply With Quote
Old 07-15-2011, 07:44 PM   #3
bus-bro's Avatar
Engine: 3208 na boat anchor
I agree with GreyEagle. Fluid and filters. Done right--can't hurt, might work.
What kind of fluid?
Old 07-16-2011, 11:07 AM   #4
GreyEagle's Avatar
What kind of fluid?
Any will work but Allison recommends TranSynd™ heavy-duty automatic transmission fluid, ..... see links
http://www.allisontransmission.com/publ ... onType=All
http://www.allisontransmission.com/service/autoapp/172/
or http://www.allisontransmission.com/service/transynd.jsp
GreyEagle
Roll - On...
Old 07-19-2011, 03:25 AM   #5
Jive Turkey's Avatar
I would inspect the vacuum modulator. Look for trans fluid in the vacuum line. Check the vacuum lines and vacuum source. replace any questionable hoses with new and put clamps on them if they do not have any. I would toss in a new vacuum modulator for ha ha's to see if that fixed the problem before taking it to a trans shop.
Jive Turkey is offline   Reply With Quote
Old 07-19-2011, 03:35 AM   #6
I would check the trans fluid condition first before any of the above. Use a clean white paper towel, rag , cloth etc. if the color is good or reasonably good and the fluid smells ok I wouldn't bother changing the fluid proceed with mentioned above.
Old 07-19-2011, 08:07 AM   #7
GreyEagle's Avatar
Allison (AT545) Shallow Pan
Use DEXRON® III Fluid or Allison TransSyndTM Full Synthetic Fluid
14.2 liters
15 quarts
Allison (AT545) Standard Pan
18.9 liters
20 quarts
Do the Shallow pan and then check and double check your fluid level.
If it's not full then add the additional fluid for the Standard pan......
INFO SOURCE http://www.justanswer.com/car/18fid-flu ... ssion.html
GreyEagle
Roll - On...
Old 07-19-2011, 10:32 AM   #8
Stuff's Avatar
so buy a 5 gallon pail of it and pay bulk cost rather then quart cost lol
Old 07-20-2011, 03:53 PM   #9
GreyEagle's Avatar
Allison link .... http://www.allisontransmission.com/publ ... onType=All
goto bus series under vocational at bottom of page... click on bus series
Item 1 is for the ALLISON 500 SERIES ........LINK http://www.allisontransmission.com/site ... +modulator
Before you order any parts get the serial number and double ck all your carburetor vacuum lines...
The modulator should only be used after appropriate troubleshooting has been completed,
such as verifying that the carburetor is performing properly, vacuum lines are in good
condition (no leaks or splits), etc.
The new kit, P/N 29501199, is purple in color and can be purchased through the ATD
http://www.allisontransmission.com/serv ... wnloadID=9
GreyEagle
Roll - On...
Old 07-20-2011, 08:39 PM   #10
GreyEagle's Avatar
Pretty sure all ALLISON AT545's have the vacum modulator.
Get the serial number of the tranny, you will need it if you contact Allison, it's on the tag attached to the tranny, then check with Allison and/or one or more of the diesel forums to gather info. There are hundreds of diesel forums out there with way more info than I can give.
If you google Allison AT545 you can get alot of links to additional info. good luck
GreyEagle
Roll - On...
Old 04-12-2012, 04:26 AM   #11
first, transynd is expensive, and something like the c-4 or atf (ford) would be better for checking on suspect tranny. (I will not use dexron when i rebuild trannys)
Second, there are tons of used and many low mileage 545's out there as a huge number of skoolies in the northwest have them in the junkyards.. even 643's, etc.. like the truck junkyard in sheridan, oregon. They frequently sell them for $500 or so for a good one.
You can also purchase 545's cheaply for a rebuilt one, from at least two rebuilders in california.. Probably around 1800 or so when you send core back. I know 643's are around that price, and some parts that you may need that aren't included in a rebuild kit are kinda expensive.
you can also pressure test them.
If it were me, and i was having something other than a clogged filter or misc easily fixable problem, i would just buy a rebuilt one from a good rebuilder... cause they are cheap, and even though i can rebuild one, the parts could easily eat up $1000 or more depending on what extra parts are needed.
Allison MT654CR ScottT Classifieds | Buy, Sell, Swap 0 10-29-2014 09:42 PM
Allison 643 $500 TN GreyEagle Classifieds | Buy, Sell, Swap 0 07-15-2012 11:20 AM
P30 chassis on '00 Mini Bird Shifting buswizard GM | Chevrolet Drivetrain 0 10-29-2010 06:16 AM
CAT V8 Diesel and 6 spd Allison FF FRED Classifieds | Buy, Sell, Swap 0 03-08-2010 06:15 AM
Switch from Allison 643 to Allison 545 the_experience03 Conversion General Discussions 3 02-13-2008 08:44 PM
