Old 09-03-2015, 02:20 PM   #1
Chassis: Saf-T-Liner MVP ER
Engine: CAT 3126b Rotella-Chugger
Anybody ever do any suspension work?
Hey,
So after returning from our 9,000 mile US trip this summer, we collectively determined one thing about my bus: the suspension and ride quality is HORRIBLE! I know it is a leaf-sprung school bus, but it is seriously unbearable, especially in Michigan and any rough roads.
The front leaf spring bushings (where the bolt goes through) are completely shot, the front ones are heavily worn and the rears are just GONE. Completely disintegrated and fell out, so there is no "cushion" over bumps and it is probably a leading cause as to why there is so much play in the steering, and why it wanders so badly. I am not sure about the shocks, but those are cake to replace and if I find the parts and they aren't crazy expensive I'll do so.
I doubt I would tackle this myself, but has anyone ever replaced leaf spring bushings on a truck this size, or had a shop do it? I have never messed with truck suspension (straight axle / leaf) only macpherson or semi-trailing arm car-style suspension. The front axle bushings seem easy enough to get to, and are in by far the worst shape. I doubt the leaf would even need to come off the bus / off the axle.
I appreciate any advice. Thanks!
porkchopsandwiches is offline   Reply With Quote
Old 09-03-2015, 02:31 PM   #2
It takes bigger tools and that is easy part
HARDEST PART IS SAFETY when I work on the bus I use solid steal and aluminum blocks as cribbage, also the big oak cribbage blocks work good after blocking make sure bus frame is on the blocking and can't drop onto it
Nat has some pictures that show his cribbed up ask him if you need help with it
be prepared to cut nuts and bolts incase they are seized and or worn oval etc
take pictures and be safe, the job is fairly easy, just big heavy parts and tools
Old 09-03-2015, 08:25 PM   #3
Most buses have leaf springs seriously over rated for their max load of passengers and ride like tanks. You can usually lighten the spring rate by as much as 50% (depending on your final build weight) but need good shocks to control the rebound. Plenty of sources for springs but Eaton Detroit has the best knowledge/service I have run across.
Old 09-04-2015, 10:24 AM   #4
opus's Avatar
Chassis: All-American R/E
Bring it to a GOOD spring shop, tell them your desires and let them have at it!
Old 09-04-2015, 11:27 AM   #5
Engine: 190hp 5.9 Cummins
We change out springs at the bus shop all the time.
Not hard, you just need 20 ton bottle jack, big blocks of wood, Big hammer, big tools, angle grinder with cutoff blade, and time.
Shocks are usually harder to get off than the springs. Some buses have 4 per front wheel. Adds up to big $$ to replace them all.
For us to pass the commercial safety ( CVIP) All original equipment must be replaced. No parts can be removed and not replaced.
Watch some videos on you tube about your air brakes and they are a walk in the park too compared to some of the work you did on your engine.
Old 09-07-2015, 05:38 PM   #6
Cool, thanks guys. I will look into doing this...eventually.
