Old 07-25-2010, 10:06 PM   #1
bus-bro's Avatar
Engine: 3208 na boat anchor
Re: AT545 overfull!
2500 rpm, 55 mph. What is your rear end geared at. That may be what it runs at in 4th.
Old 07-25-2010, 10:58 PM   #2
frank-id's Avatar
To begin
Check the side of the trans for an ID. tag. This tag will identify the unit. Most Allison trans have a drain plug. As a last resort to drain some fluid, get a helper that can stop and start the engine, a five gallon bucket and remove a line from the oil cooler. After a line is removed from the trans cooler, and with the engine at an idle, allow the bucket to fill half way. Stop the engine, replace the cooler line and start the engine and check fluid level. This is a quick easy task
with no danger of making any problems. It maybe necessary to add fluid or remove fluid. You can send a check or money order. Frank
Old 07-27-2010, 11:03 AM   #3
frank-id's Avatar
While checking over the trans...
In my experiences, I have found several buses to have a defective trans fluid cooler that has become defective. The cheap method of keeping trans fluid cool is to use engine coolant with a heat exchanger. The other method of keeping trans fluid cool is to have a dedicated cooler, preferable with a large fan. If engine coolant is found drain the trans quickly and check the smell and color of the trans fluid. Frank
Upgrade from DT360 and AT545? iverSUN Mechanical and Drivetrains 8 08-17-2014 09:14 PM
AT545 and Mountain driving turf Mechanical and Drivetrains 21 11-13-2013 03:45 PM
at545 transmission The Wanderer Classifieds | Buy, Sell, Swap 15 05-24-2007 12:13 AM
Does a MT643 fit instead of a AT545 ????? Protecx Conversion General Discussions 1 02-09-2007 09:14 PM
I need a Used or Rebuilt Transmission (AT545) ParadigmCrime Everything Else | General Skoolie Discussions 6 09-10-2006 10:04 AM
