Old 03-23-2015, 11:01 AM   #11
Chassis: International 1753
Engine: 6.9 International
Originally Posted by crazycal View Post
The MT643 needs a #2 and the AT545 needs a #3. Usually a DT466 has both, one bolted onto the other for the AT545.
Yes, I forgot to mention that I'm currently using an at545 which has the neck down for the sae3 housing. He will likely have the same neck down which will need to be removed. That elimination of the neck down might require elimination/creation of spacers behind the flywheel to set up the correct converter distance/depth into the trans. Your driveshaft will also for sure have to be shortened because IIRC the mt643 is something like 4" longer then the at545 that you're removing.
Old 03-23-2015, 11:57 AM   #12
Chassis: I.H.
For what its worth, this makes me think about a cooler install if he doesn't have one now. 4" is a lot. Could the motor be mounted back farther with fabricated brackets so the drive shaft is long enough and then have enough room to place a cooler in front of the radiator? It would make room to move the radiator back which eliminates that problem. I suppose it depends on the room he has behind the motor. Just creative thinking here.
Old 03-23-2015, 06:10 PM   #13
Engine: 190hp 5.9 Cummins
Your better off modifying the drive shaft.
Moving a engine is way way more work. Many many connections to a ton of different things.
Old 03-23-2015, 06:18 PM   #14
Engine: TE 444
Rated Cap: 12
with the MT643 there should be no tranny heating issues because of the lock up torque converter, the build in cooler will be sufficient
Old 03-24-2015, 12:28 PM   #15
mtg
Chassis: International 3600
Engine: T444
Rated Cap: 39
The converter in the MT643 only locks in 3rd and 4th gears. So, if you're climbing steep hills, it's probably still a good idea to add a transmission cooler.
I have one on my bus, because we are driving through the mountains of Colorado with an AT542. It was required. We mounted it in the front bumper, only had to add one short section of hose from the radiator intercooler over to the oil cooler, and reused the old return line. Doing this while swapping the transmission would probably only add 10% more work.
mtg is offline   Reply With Quote
