Do any of the rear engine buses have an AT545 tranny? So many of the auctions only specify that it is an automatic transmission and some cannot tell me what the model# is.
ther 643 and 545 use the same shifter.. underside pics you can tell tjhe difference in trans... the 643 has a ring of bolts around the tailshaft the 545 does not.
the shifters on the 1000/2000 will say N-D-4-2-1. the shifter for a 3000 will always have a display.. even if its the T-handle shifter will have a digit display. and the pushbutton shifter is a 3000 (usually MD3060).
