Old 02-24-2013, 02:28 AM   #1
Year: 1974
Engine: Detroit Diesel 6-71
Re: Blackstone Lab
Thank you so much for posting. I was on their website yesterday and decided that this will be a top priority for our bus (be great if we can do it before we buy). Might have our race car checked out also.
Proud new owners of a 1974 Crown Supercoach - the big rolling twinkie!
viewtopic.php?f=9&t=466562
inkblots84 is offline   Reply With Quote
Old 02-24-2013, 08:37 AM   #2
Re: Blackstone Lab
Originally Posted by BigTex
...Thus, I climbed under the bus and ever so gently loosened the oil pan and transmission pan drain plugs until a trickle of oil started running out. Yeah it took 10 minutes to fill the tube, but I didn't have to drain the engine / transmission for a sample.
Tex, could the high iron in the trans be from the drain plug itself? Just a thought. Thanks for posting this info, it is nice to "know" what your oil is doing!
100MPG is offline   Reply With Quote
Old 02-26-2013, 09:33 AM   #3
crazycal's Avatar
Re: Blackstone Lab
I thought about doing this a while back but just got lazy. I found out about oil analysis from a maintenance foreman many years ago. When dealing with construction equipment, I guess a $50k engine is not uncommon.
BigTex, now you have a base line you can compare future analysis' to.
I'm hungry!
You Gotta Let Me Fly
Old 02-26-2013, 01:22 PM   #4
Re: Blackstone Lab
I hear thats going around a lot...I got it too!
Old 02-26-2013, 06:15 PM   #5
opus's Avatar
Chassis: All-American R/E
Re: Blackstone Lab
I use them every other oil change.
Old 02-27-2013, 08:41 PM   #6
bus-bro's Avatar
Engine: 3208 na boat anchor
Re: Blackstone Lab
25 bucks for a test isn't too bad, but add it to 5 gals. of oil and a filter, or two --ouch!
bus-bro is online now   Reply With Quote
Old 02-27-2013, 08:46 PM   #7
opus's Avatar
Re: Blackstone Lab
Better to pay now and avert a rod through the block or spinning a main bearing.
Old 02-27-2013, 11:43 PM   #8
bus-bro's Avatar
Re: Blackstone Lab
2000 for a bus, 100 for an oil change, 3000 for tires. Bus'n ain't really cheap, is it?
Old 02-27-2013, 11:47 PM   #9
opus's Avatar
Re: Blackstone Lab
You forgot to add in the high resale value.
Old 02-28-2013, 12:12 AM   #10
bus-bro's Avatar
Re: Blackstone Lab
